When did Chrysler switch to Cast Iron six pack manifolds?
#2728364
12/30/19 06:07 PM
12/30/19 06:07 PM
Posts: 1,149 NW New Jersey
RSI700VIPER
NW New Jersey
I have a six pack challenger built in November of 1969. Would my car come with an aluminum or cast iron manifold?
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: When did Chrysler switch to Cast Iron six pack manifolds?
[Re: RSI700VIPER]
#2728414
12/30/19 09:19 PM
12/30/19 09:19 PM
Posts: 43,118 Bend,OR USA
Cab_Burge
I had a V code 1970 Charger R/T 4 speed car bought new in Victorville, CA in November of 1969 by the original owner. I ended up becoming the 3rd or 4th owner of it in 1the spring of 1989 with the car being bought taken apart and missing the original Dana 60, 4 speed console six pack set up and the original block, the original owner had the short block replaced in the early spring of 1970. It had a SPD of 10-28-1969 under warrenty for some unknown reason . I ended buying a late production 1969 dana 60 out of a 1969 Charger R/T and I was lucky enough to buy two different 1970 cast iron six pack set ups, one with non CA six pack carbs for the manual trannies and one CA set up for the automatic CA cars. One of the cast iron intakes had a casting date of 10-21-1969 and the other one had a casting date of 10-28-1969 so that makes me think that Mopar switch to the cast iron 6 pack intakes in the early production run of the 1970 cars IHTHs
[Re: topside]
#2728452
12/31/19 01:29 AM
12/31/19 01:29 AM
Posts: 17,515 Las Vegas, NV
6bblgt
Las Vegas, NV
there is an "early" & a "late" cast iron 440+6 intake - casting number 2946275 VS. 2946276 (& then a third design with the same 2946276 part # on it between the carb mounts) I've heard rumors about the first design being "porous" or some other casting flaw causing Chrysler to purchase every aluminum intake available at Edelbrock to keep the engine assembly line moving while the intake was being redesigned/reconfigured the 1970 model year started production with the cast iron intake & in the time gap between "275" & "276" manifolds is where the aluminum manifolds are found during 1970 engine production I've seen a number of November scheduled cars with aluminum intakes, but more importantly would be the engine assembly dates, when the engine was assembled at the Trenton engine plant the first design "276" intake has a casting/parting line down the center of the manifold who has access to a 1970 440+6 car with its original engine and an aluminum intake? what's the car's: assembly plant, SPD & engine assembly date?
[Re: 6bblgt]
#2728467
12/31/19 08:06 AM
12/31/19 08:06 AM
Posts: 6,388 Abilene, Texas
fastmark
Abilene, Texas
As usual, Dan, you amaze me with information that I’ve never heard of and have pictures to prove it! My Superbird was build in Late Nov. I’ll look today at the assembly date of the block and casting info of the manifold. It’s cast iron but it’s the original one as far as I know. I bought it in 82 with 65,000 miles and the engine had never been apart.
[Re: fastmark]
#2728479
12/31/19 09:23 AM
12/31/19 09:23 AM
RSI700VIPER
NW New Jersey
Very informative. I'll have to check my assembly date. The engine is numbers matching and the manifold is aluminum, but I don't have a complete history of the car.
[Re: sixbbl 69]
#2728486
12/31/19 09:56 AM
12/31/19 09:56 AM
Posts: 6,224 JERSEY
RJS
JERSEY
One thing I would like to add to this, when I had a 70 440+6 Cuda it had an aluminum on it when I purchased but came with the car's original cast iron. Wanting to put it back to as original as possible I re-installed the cast iron intake and it had a noticeable seat of the pants difference in performance. Maybe the cast iron was a bit more restrictive???? But my hiney felt it! Ron
[Re: RJS]
#2728508
12/31/19 11:54 AM
12/31/19 11:54 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
The "heft-o-meter" says it feels like a Ford FE intake, ~ 80 lbs. vs. 25 ~ 30 for the aluminum? 2¢
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: RJS]
#2728511
12/31/19 12:10 PM
12/31/19 12:10 PM
Posts: 8,392 Highland, MI.
Sunroofcuda
Highland, MI.
One thing I would like to add to this, when I had a 70 440+6 Cuda it had an aluminum on it when I purchased but came with the car's original cast iron. Wanting to put it back to as original as possible I re-installed the cast iron intake and it had a noticeable seat of the pants difference in performance. Maybe the cast iron was a bit more restrictive???? But my hiney felt it! Ron So you are saying the aluminum Edelbrock noticeably performed better? Question: the 340 6-packs. Was there both alum. & cast iron in those as well? I haven't lifted mine in a while, but I think it is iron. Now I'm curious.
[Re: Sunroofcuda]
#2728529
12/31/19 12:49 PM
12/31/19 12:49 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
My Superbird has the original 276 CI Intake that was cast 10/23/69. My engine was assembled 11/5/69 and car was assembled 11/12/69 Jim
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
[Re: Sunroofcuda]
#2728536
12/31/19 01:30 PM
12/31/19 01:30 PM
6bblgt
Las Vegas, NV
Question: the 340 6-packs. Was there both alum. & cast iron in those as well? aluminum only
[Re: 3hundred]
#2728560
12/31/19 02:31 PM
12/31/19 02:31 PM
3hundred
Colleyville
Found somebody weighed theirs, 41 lbs. Alum should be ~ 1/3 of that.
MANY years ago I saw that the FE Ford was 84 lbs. Sure felt about the same when lifted, guess the 84 was wrong?
[Re: NANKET]
#2728586
12/31/19 03:41 PM
12/31/19 03:41 PM
6bblgt
Las Vegas, NV
from the other thread "NANKET" I have one 2946276 dated 8-20-69 can you get pics of this casting number? does anyone have an intake cast between Thursday 9/25/69 & Wednesday 10/22/69?
