Jeep A500 TF to fit LA Block? #2728379
12/30/19 07:32 PM
12/30/19 07:32 PM
Australia
fullonmopar Offline OP
Australia
Torque Flite A500s were never released down under except in certain model Jeeps. What are the possibilities of fitting a Jeep A500 to an LA block to replace the old three speed TF, is it just a bell housing difference?
Re: Jeep A500 TF to fit LA Block? [Re: fullonmopar] #2728383
12/30/19 07:48 PM
12/30/19 07:48 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Direct swap, except for mount and driveshaft. IIRC, 6 1516" shorter is what I measured.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Jeep A500 TF to fit LA Block? [Re: fullonmopar] #2728412
12/30/19 09:15 PM
12/30/19 09:15 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Not sure on the Jeep 5.2's A500 but the 4X4 A518 I have has the starter on the right side of the bell.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Jeep A500 TF to fit LA Block? [Re: Dave_J] #2728428
12/30/19 10:39 PM
12/30/19 10:39 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
What vehicle had the A518 with the starter on the right side?
Re: Jeep A500 TF to fit LA Block? [Re: QuickDodge] #2728436
12/30/19 11:08 PM
12/30/19 11:08 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
My '98 GC 5.9 Limited had it's own, unique starter, on the passenger side. There was an adapter plate between the trans and block to facilitate the change.
Re: Jeep A500 TF to fit LA Block? [Re: QuickDodge] #2728438
12/30/19 11:23 PM
12/30/19 11:23 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
I think it was out of a 1998 Grand 5.9
65 Formula S Cuda
Re: Jeep A500 TF to fit LA Block? [Re: Dave_J] #2728441
12/30/19 11:51 PM
12/30/19 11:51 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
was the A500 ever put behind a 5.2 in a jeep?,i bought a well used 5.2 out of a jeep,it had a starter that went on the passenger side,dont know what trans it used
my ladder of success is missing some rungs
Re: Jeep A500 TF to fit LA Block? [Re: rhad] #2728994
01/01/20 02:26 PM
01/01/20 02:26 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
The 500's, 42 rh/re, were used behind the 4.0's. There was a 44re that came behind the 5.2's. The starter was on the opposite side from normal mope stuff. Kicker was that the RE series of trans were electronic, needing a controller, and the RH series were hydraulic and could be operated with a couple of toggle switches for the lock up and o/d. If my memory serves me right from my dealership parts time, the pans were the same for the two units. The 46/47/48 units use the 727 style pan. I'm not sure if you can retrofit an RE series trans to make it into an RH style.. The RE units came out in 96 for all Jeep, truck and vans. RH units are 95 back. Also, the Jeep starter is not the same as other applications.
Carl Kessel
