Re: Jeep A500 TF to fit LA Block?
[Re: fullonmopar]
#2728383
12/30/19 07:48 PM
12/30/19 07:48 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Direct swap, except for mount and driveshaft. IIRC, 6 1516" shorter is what I measured.
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: fullonmopar]
#2728412
12/30/19 09:15 PM
12/30/19 09:15 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
Not sure on the Jeep 5.2's A500 but the 4X4 A518 I have has the starter on the right side of the bell.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Dave_J]
#2728428
12/30/19 10:39 PM
12/30/19 10:39 PM
Posts: 1,160 Cruising!
QuickDodge
Cruising!
Not sure on the Jeep 5.2's A500 but the 4X4 A518 I have has the starter on the right side of the bell. What vehicle had the A518 with the starter on the right side?
[Re: QuickDodge]
#2728436
12/30/19 11:08 PM
12/30/19 11:08 PM
Posts: 1,650 Harm City Md.
Dan Halen
Harm City Md.
Not sure on the Jeep 5.2's A500 but the 4X4 A518 I have has the starter on the right side of the bell. What vehicle had the A518 with the starter on the right side? My '98 GC 5.9 Limited had it's own, unique starter, on the passenger side. There was an adapter plate between the trans and block to facilitate the change.
[Re: QuickDodge]
#2728438
12/30/19 11:23 PM
12/30/19 11:23 PM
Dave_J
Auburn WA
I think it was out of a 1998 Grand 5.9
[Re: Dave_J]
#2728441
12/30/19 11:51 PM
12/30/19 11:51 PM
Posts: 954 garnett kansas
rhad
garnett kansas
was the A500 ever put behind a 5.2 in a jeep?,i bought a well used 5.2 out of a jeep,it had a starter that went on the passenger side,dont know what trans it used
my ladder of success is missing some rungs
[Re: rhad]
#2728994
01/01/20 02:26 PM
01/01/20 02:26 PM
Posts: 668 Los Osos, Ca
CKessel
Los Osos, Ca
The 500's, 42 rh/re, were used behind the 4.0's. There was a 44re that came behind the 5.2's. The starter was on the opposite side from normal mope stuff. Kicker was that the RE series of trans were electronic, needing a controller, and the RH series were hydraulic and could be operated with a couple of toggle switches for the lock up and o/d. If my memory serves me right from my dealership parts time, the pans were the same for the two units. The 46/47/48 units use the 727 style pan. I'm not sure if you can retrofit an RE series trans to make it into an RH style.. The RE units came out in 96 for all Jeep, truck and vans. RH units are 95 back. Also, the Jeep starter is not the same as other applications.
Carl Kessel
