What clutch pkg for street? #2728352
12/30/19 05:11 PM
12/30/19 05:11 PM
In the Middle
roadntrack Offline OP
In the Middle
What clutch do you like for stock street use?
1971 Charger stock 440 4speed
Stay with the borg & beck 3 finger or go with diaphragm style?
Looking at this McLeod..
https://www.mcleodracing.com/index.php/clutch-kits/street-pro/street-pro-95284.html
Remember when cars were FUN?
Re: What clutch pkg for street? [Re: roadntrack] #2728367
12/30/19 06:14 PM
12/30/19 06:14 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I personally like the stock setup,10.95 b&b. A diaphragm will need to have the heavy spring removed from the clutch pedal assembly from what I have been told.
I have driven a few of my buddy's GM stuff with diaphragm set ups and they don't seem to be the same when you get the urge to power shift here and there.
Re: What clutch pkg for street? [Re: B1MAXX] #2728369
12/30/19 06:44 PM
12/30/19 06:44 PM
In the Middle
In the Middle
I did see a note stating that the overcenter spring needs to be removed.
Re: What clutch pkg for street? [Re: roadntrack] #2728396
12/30/19 08:21 PM
12/30/19 08:21 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Centerforce here. The was a recent post where the CF assemblies got a lot of up twocents beer
CLUTCH POST
Re: What clutch pkg for street? [Re: TJP] #2728415
12/30/19 09:20 PM
12/30/19 09:20 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Previous 4-speed car, I put a Centerforce diaphragm in it and was happy with it: easy to work & modulate, plenty of clamp.
Current car, prior owner put a McLeod diaphragm in it; higher leg effort, narrow "window" to modulate. I don't like it as much.
Both street cars, both B-bodies.
Re: What clutch pkg for street? [Re: topside] #2728525
12/31/19 12:42 PM
12/31/19 12:42 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Way back I used to race my 1970 charger rt (4-speed) against a dude at the track occasionally that had a 70 boss 302 mustang (4-speed) for fun. That was back when the centerforce had just came out which he had, and would use the excuse of the clutch pedal sticking down occasionally whiney. I want to say that he would run it up to/past 7000. I have no idea if it was true though. shruggy
Re: What clutch pkg for street? [Re: B1MAXX] #2728595
12/31/19 04:00 PM
12/31/19 04:00 PM
South San Francisco, Ca
70sixpkrt Online content
70sixpkrt  Online Content
I am using the Mcleod Borg and Beck 3 finger. Mcleod doesn't make the pressure plate anymore(360153). I have a used pressure plate that Mcleod rebuilt and will be installing it next month. Passon Perf and Brewers sells Ram clutch kits. Both of them have had no issues with them so far.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: What clutch pkg for street? [Re: B1MAXX] #2728596
12/31/19 04:01 PM
12/31/19 04:01 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Back in about 1970, I ran a Scheifer Rev-Lok diaphragm clutch that would stick to the floor at anything over 6K. The solution was to adjust the linkage so that there was only 30 thousands clearance between the disk and flywheel when the pedal was fully depressed. That made for about two inches of free play at the top. Solution to that was a really heavy spring to bring the clutch pedal up to the top so it felt like a normal clutch. No doubt the linkage could have been reworked to change the bellcrank ratios, but why bother. That diaphragm clutch had a really soft feel, but it locked up much better than the 3000 pound three finger clutch I had before.
Re: What clutch pkg for street? [Re: John Brown] #2728678
12/31/19 09:11 PM
12/31/19 09:11 PM
Banana Republic
FM3AAR Offline
FM3AAR  Offline
Banana Republic
McLeod diaphragm here and very happy with it.
Ehrenberg recommends a diaphragm over the stock finger style on the street.
“You’ll own nothing” — And “you’ll be happy about it.”
K. Schwab
Re: What clutch pkg for street? [Re: FM3AAR] #2728839
01/01/20 08:54 AM
01/01/20 08:54 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Center force behind my 600HP 440.Great setup and works great.I used to run McCleod 3500 pound 3 finger.Switching was the best thing i did.Rocky
Chrysler Firepower
Re: What clutch pkg for street? [Re: therocks] #2730547
01/06/20 01:52 PM
01/06/20 01:52 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Let's try to say this without upsetting the purists. 1st of all, if the car needs to stay correct. No choice but to go Borg n Beck, it's proper.
Now onto the facts. All 3 finger set ups are old technology. The pedal has the most spring pressure at the wrong time, when it's released. The least amount when the clutch is engaged. So if the disc slips you need to add more spring pressure. What happens is you get a tiny bit more on the disc but mostly on your left leg.
A diaphram style places most of it's pressure on the disc while it's clamped. Basically it goes over center when it's released making the same pressure plate that can contain alot of power, easy to disengage.
Centerforce for me.
