360 magum/904 flexplate #2727081
12/26/19 02:48 PM
12/26/19 02:48 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
360 Magnum previously run with a 727. Now going with a 904. Which flex plate do I use? I heard at one time the 727 magnum flex plate will interfere with the starter on a 904.
Thanks Doug
Re: 360 magum/904 flexplate [Re: dvw] #2727546
12/27/19 10:57 PM
12/27/19 10:57 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Nobody has used a Magnum 360 with a 904?
Doug
Re: 360 magum/904 flexplate [Re: dvw] #2727577
12/28/19 12:41 AM
12/28/19 12:41 AM
Wisconsin
wkroncke17 Offline
wkroncke17  Offline
Wisconsin
Doug
I just asked in the race section not long ago about a 360LA/904.
The 360 I asked about will be internally balanced.
In all of the questions and answers, phone calls made to manufacturers, I found out the 360 (internally balanced) uses the same flex plate as a big block, and either the 727 or 904.
I know you asked about a 360 magnum, (externally balanced I assume) I can’t answer if there’s any differences.
Doubt it helps, but it’s what I know.
Wally.
Re: 360 magum/904 flexplate [Re: wkroncke17] #2727624
12/28/19 10:50 AM
12/28/19 10:50 AM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Same flexplate as an LA would use, assuming it's carbed. Make sure your torque converter has the Magnum imbalance weight on it.
Re: 360 magum/904 flexplate [Re: Sniper] #2727844
12/28/19 09:02 PM
12/28/19 09:02 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
LA and Magnum don't have the same amount of imbalance. Magnum flex plates are available to fit neutral balance converters. Just not sure if there is a part that fits the 904 trans.
Doug
Re: 360 magum/904 flexplate [Re: dvw] #2727849
12/28/19 09:24 PM
12/28/19 09:24 PM
nowhere
nowhere
You put the imbalance weight on the torque converter, not the flexplate. Use a 904 flexplate and a P5249843 kit to balance the torque converter for a Magnum 360, instructions should be in the kit but you position the included weights, weld them on and done.
Re: 360 magum/904 flexplate [Re: Sniper] #2727943
12/29/19 10:52 AM
12/29/19 10:52 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
The factory built flex plates with the imbalance weight welded on for Magnums. Just cant find the part number. I have welded the converters in the past.
Doug
Re: 360 magum/904 flexplate [Re: dvw] #2727958
12/29/19 11:22 AM
12/29/19 11:22 AM
nowhere
nowhere
Doubtful there is a part number for a factory Magnum flexplate that fits the 904 since no 904 was put behind a Magnum 360.
Not even sure that the A500 was either. You can find the weighted Magnum flexplate for the 360 but it goes with the A518 type trans. (98 B2500 for example). Will it fit your application? I dunno.
Re: 360 magum/904 flexplate [Re: Sniper] #2728002
12/29/19 02:06 PM
12/29/19 02:06 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
B&M used to produce an SFI approved flexplate for this swap: 5.9L Mag to 904. Part number was 10241. It was discontinued years ago, but you may be able to find one if you don't want to go through the headache of welding weights on the TC.
Re: 360 magum/904 flexplate [Re: MarkZ] #2728127
12/29/19 08:34 PM
12/29/19 08:34 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Try PRW
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: 360 magum/904 flexplate [Re: Adobedude] #2728237
12/30/19 09:59 AM
12/30/19 09:59 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Looks like I'll weld them on. I didn't think this was that oddball a combo. PRW doesn't have one either.
Doug
