2500 battery replacement
#2728099
12/29/19 07:14 PM
12/29/19 07:14 PM
Posts: 16,469 On the run…
BloFish
On the run…
The time has finally come to replace my batteries, any suggestions as to which brand? Based upon my limited research I’m leaning towards Interstate.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
Re: 2500 battery replacement
[Re: J_BODY]
#2728178
12/30/19 12:14 AM
12/30/19 12:14 AM
Posts: 5,783 Corpus Christi, TX
shanker
Corpus Christi, TX
I went though my second set of Optima red tops a little over a year ago in my 01.... last time I bought them they were $114 ea.... Now they’re $230. I’m currently trying some Duracell AGM batts from sams club. I couldn’t bring myself to spend $500 for a pair of batteries.
I will say my battery cables and ends look factory new. I’ve cleaned and repaired so many corroded up messes from wet batteries I’ll always go AGM in my pickup. Those Duracell AGM batteries from Sams are awesome. (I have them in my daily driver & my wife's daily driver & the Duster) The top tier battery currently right now is an Odyssey (Its what I have in my Coronet R/T)
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
[Re: shanker]
#2728187
12/30/19 01:06 AM
12/30/19 01:06 AM
BloFish
On the run…
I’ll look into the group 65.
[Re: BloFish]
#2728504
12/31/19 11:45 AM
12/31/19 11:45 AM
Posts: 16,128 Mesa, Arizona
dart4forte
Mesa, Arizona
Just replaced my driver side battery with a Motocraft. Had the best warranty. The battery had a crack around the positive post. I was changing out the negative cable on the passenger side battery and it too had a crack. The environment here in Phoenix is really hard on batterys.
Abe Lincoln
