Page 3 of 3 1 2 3
Re: Question about fitting subframe connector [Re: CMcAllister] #2727841
12/28/19 08:59 PM
12/28/19 08:59 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Originally Posted by CMcAllister
These days, most serious builds and those that need to have an SFI tag are all round tube. And it's 4130. 1.500x.065 frame rails but there is also plenty of diagonals and bracing as well.
Agreed,two different style builds. Those that are milder using the body and cage as one structure. And those trying to be as light as possible being 25.5D compliant. The sheet metal is merely visual and not much structure.
Doug
Re: Question about fitting subframe connector [Re: dvw] #2727845
12/28/19 09:07 PM
12/28/19 09:07 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I disagree. SFC IMO mainly improve/shortcut the original torturous load path of transmitting forces from the front leaf spring mount, to the rear torque box, to the outer door sill, to the front torque box, to the TB cross member, to the front frame longitudinal.
The original designers were forced to made a number of compromises.
Re: Question about fitting subframe connector [Re: DrCharles] #2728268
12/30/19 11:34 AM
12/30/19 11:34 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Differences in wall thickness affect stiffness (bending resistance) in direct proportion: .120" wall is 33% more than .090", etc.
The vertical dimension is far and away the most important. 3" tall by 2" wide is 90% more rigid than 2" tall by 3" wide (47% stiffness is lost by rotating).
Boffin Emeritus
Page 3 of 3 1 2 3
