68 -70 340 exhaust manifolds #2726930
12/25/19 10:29 PM
12/25/19 10:29 PM
NC
Sixt8Chrgr Offline OP
NC
I am looking to purchase the above and have come to realize that some manifolds have the casting number with the pentastar logo and some manifolds have no pentastar. Also the date codes on some manifolds are very clear on the manifold and some manifolds don’t have any? Are the manifolds without the PENTASTAR service replacements?
Thanks!
Re: 68 -70 340 exhaust manifolds [Re: Sixt8Chrgr] #2726931
12/25/19 10:31 PM
12/25/19 10:31 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
340?
If so, sometime during the 1970 model year a new casting with no embossed / cast numbers on the driver side manifold.
Re: 68 -70 340 exhaust manifolds [Re: Alaskan_TA] #2726934
12/25/19 10:47 PM
12/25/19 10:47 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
There should be numbers in the back near the bend in the 1970 style drivers side manifold. Pretty much all 68-69 manifolds have the numbers on the front surface.
JB Rhinehart, Realist
A-Body's RULE!
Re: 68 -70 340 exhaust manifolds [Re: Rhinodart] #2726944
12/26/19 12:02 AM
12/26/19 12:02 AM
FL
moparwizard Offline
moparwizard  Offline
FL
I have a original 340 assembled in April of 1970, that does not have any casting numbers or dates on either manifold.
Re: 68 -70 340 exhaust manifolds [Re: moparwizard] #2726953
12/26/19 01:01 AM
12/26/19 01:01 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
1969 Barracuda 340, scheduled build date 11/8/68, actually built late November 1968, engine assembled 11/1/68. No Pentastar on one manifold that was cast 10/15/68.
Re: 68 -70 340 exhaust manifolds [Re: moparwizard] #2726994
12/26/19 09:46 AM
12/26/19 09:46 AM
NC
NC
Originally Posted by moparwizard
I have a original 340 assembled in April of 1970, that does have any casting numbers or dates on either manifold.
Will you confirm? Does or does not have the date codes?
My car is a March 11 built AAR
Re: 68 -70 340 exhaust manifolds [Re: Sixt8Chrgr] #2726997
12/26/19 10:01 AM
12/26/19 10:01 AM
Rhinotruck
Rhinotruck
Here is a pic of the date code on my 70 340 manifold
A-Body's RULE!
Re: 68 -70 340 exhaust manifolds [Re: Sixt8Chrgr] #2727005
12/26/19 10:36 AM
12/26/19 10:36 AM
FL
moparwizard Offline
moparwizard  Offline
FL
No casting numbers No casting dates. Engine was assembled 4/16/70. Here are some pictures after I pulled them off the engine , bead blasted them and repaired the heat riser.
Re: 68 -70 340 exhaust manifolds [Re: moparwizard] #2727155
12/26/19 06:24 PM
12/26/19 06:24 PM
Rhinotruck
Rhinotruck
They could be the reproduction manifolds, though the passenger side does not come with the flapper it could have been added.
A-Body's RULE!
Re: 68 -70 340 exhaust manifolds [Re: Rhinodart] #2727158
12/26/19 06:29 PM
12/26/19 06:29 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Only if the reproductions come with rust pits?
Re: 68 -70 340 exhaust manifolds [Re: Alaskan_TA] #2727166
12/26/19 06:49 PM
12/26/19 06:49 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
I never found any numbers or date codes on my T/As exhaust manifolds. I’ve had the car since ‘78 and it’s numbers matching, so I assume they are the originals.
Re: 68 -70 340 exhaust manifolds [Re: Rhinodart] #2727193
12/26/19 08:07 PM
12/26/19 08:07 PM
FL
moparwizard Offline
moparwizard  Offline
FL
Not repos, here's a pic from a few years ago in the car with the worn out riser wired open.
Re: 68 -70 340 exhaust manifolds [Re: Alaskan_TA] #2727203
12/26/19 08:33 PM
12/26/19 08:33 PM
sw michigan
TB3CUDA Offline
TB3CUDA  Offline
sw michigan
sent you pics of mine didnt hear anything from you.
Re: 68 -70 340 exhaust manifolds [Re: moparwizard] #2727255
12/27/19 01:34 AM
12/27/19 01:34 AM
Rhinotruck
Rhinotruck
Pictures always help, where were those earlier? I have never seen a set without casting numbers and date codes, that is why I said that and I have probably seen over 1000 sets. Anything is possible when you talk about Chrysler... shruggy
A-Body's RULE!
Re: 68 -70 340 exhaust manifolds [Re: Alaskan_TA] #2727257
12/27/19 01:39 AM
12/27/19 01:39 AM
Rhinotruck
Rhinotruck
Have you done a metallurgical test to see if they are cast with the same process as the originals? I didn't think so... eyes
A-Body's RULE!
