Brake Line Vendors
#2726268
12/22/19 09:54 PM
12/22/19 09:54 PM
Posts: 1,111 Usa
A39Coronet
Usa
Who do you like using for brake line replacement? I ordered a set from Right Stuff and every single line needed adjusted and modified. The front lines that went under the frame from the distribution block to the flex lines weren't bent wide enough to clear the frame by over an inch (the "U" shaped valley is narrower than the frame is wide by over an inch). Is this par for the course or are they're more accurate companies out there?
It even appears they put the wrong firewall line in the box as it was tagged with a different part #.
Re: Brake Line Vendors
[Re: A39Coronet]
#2726275
12/22/19 10:35 PM
12/22/19 10:35 PM
Posts: 2,092 New Mexico
JMCFAN
New Mexico
Used In line tube... brake lines fit fine....but I think you will alway have to slightly bend etc......
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: A39Coronet]
#2727320
12/27/19 10:57 AM
12/27/19 10:57 AM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
Right Stuff is fairly local to me and I liked using them because I did not have to deal with having to straighten the lines. In the early days got great personal customer service.
But they are not as good in my opinion as they used to be since they got bought out by a large company a few years ago. They lost the personal service touch now that they are much bigger. Last time I bought lines from them they were fair.
