Balast Resistor voltage?
#2724905
12/17/19 07:35 PM
12/17/19 07:35 PM
Posts: 4,707 Star Idaho
67vertman
Star Idaho
How many volts should be coming out of the ballast resistor to the positive side of the coil?
I have 5.5......is that correct or is my resistor bad?
My Monster are real!
Living within your means makes life pretty easy.
Re: Balast Resistor voltage?
[Re: 67vertman]
#2724912
12/17/19 07:56 PM
12/17/19 07:56 PM
Posts: 6,220 nowhere
Sniper
nowhere
Depends on what's on the other side of the ballast. Was that with the engine running? From another thread where I posted the readings I got on my setup to help with a similar question. When out to the 51 and took some measurements.
It's a 51 Plymouth Cambridge I converted to 12v negative ground using a Mopar alternator and voltage regulator. Stock points ignition with Mopar ballast and 12v coil.
engine off, key in run I see 12.2V at the battery (low, should be 12.8v ish) and 6.2v at the coil +, all grounds taken at the battery negative terminal.
engine running, 12.8V at the battery (low, should be 13.8v ish, need to up the idle speed) and 8.8v at the coil +, all grounds taken at the battery negative terminal.
[Re: Sniper]
#2724955
12/17/19 10:15 PM
12/17/19 10:15 PM
67vertman
Star Idaho
engine running, 12.8V at the battery (low, should be 13.8v ish, need to up the idle speed) and 8.8v at the coil +, all grounds taken at the battery negative terminal. Thanks, this is with the engine off and key to the run position. The battery was at 13.2 and 5.5 to the ballast and 5.4 to the coil. The problem I encountered is a no start issue. and no spark to the plugs. I though maybe the ballast went bad....time to check some other things. Note. that the end of the ballast was loose, and when I tried to tight it, it broke off. so I need to replace that.
[Re: Sniper]
#2724977
12/17/19 11:04 PM
12/17/19 11:04 PM
67vertman
Star Idaho
One side of your ballast should be real close to the same voltage as at the battery +. If it's not you have issues upstream of the ballast. Once you get the new ballast installed check that. Thanks again, I didn't check what was coming in, only going out, as when I checked the positive side of the coil, the voltage was 5.4 (at the coil) so I decided to check what was coming out of the ballast to coil 5.5 volts. I can check the voltage to the ballast to see if its a 12.0 or better.
[Re: 67vertman]
#2725187
12/18/19 06:52 PM
12/18/19 06:52 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
In Run, engine off, the voltage of the current flowing into the reistor should be within a 1/2 Volt of the battery reading taken at the same time. I don't believe the battery was at 13.2 Volts while the key was switch on. 12.8 Volts is about maximum for the stored power. Readings above that are usually surface charge. Surface charge disapates very quickly when a load is placed across the battery (flip the lights on, dome light, etc). Under very heavy load, the votlage will termporarily drop lower. For example, during starting the voltage will drop down to 10 Volts or a even less depending on battery condition. Chrysler tech used 9.6 Volts at the coil as the rule of thumb when measuring at the coil during start. And a maximum of 1/2 Volt drop between battery and run circuit with key in run and engine off. p. 9, 1969 Ignition System Analysis http://www.imperialclub.com/Repair/Lit/Master/259/Page09.htmMight want to print that pamphlet. Not sure how much longer the Imperial Club website will be around. (link to larger printable version of available at bottom of page)
[Re: Jim_Lusk]
#2725265
12/19/19 12:23 AM
12/19/19 12:23 AM
67vertman
Star Idaho
That voltage is pretty close to correct. Points or electronic? If points you probably have the points stuck closed. If electronic check the ignition box and its ground. Thanks Jim, its still has points.
[Re: Mattax]
#2725268
12/19/19 12:25 AM
12/19/19 12:25 AM
67vertman
Star Idaho
In Run, engine off, the voltage of the current flowing into the reistor should be within a 1/2 Volt of the battery reading taken at the same time. I don't believe the battery was at 13.2 Volts while the key was switch on. 12.8 Volts is about maximum for the stored power. Readings above that are usually surface charge. Surface charge disapates very quickly when a load is placed across the battery (flip the lights on, dome light, etc). Under very heavy load, the votlage will termporarily drop lower. For example, during starting the voltage will drop down to 10 Volts or a even less depending on battery condition. Chrysler tech used 9.6 Volts at the coil as the rule of thumb when measuring at the coil during start. And a maximum of 1/2 Volt drop between battery and run circuit with key in run and engine off. p. 9, 1969 Ignition System Analysis http://www.imperialclub.com/Repair/Lit/Master/259/Page09.htmMight want to print that pamphlet. Not sure how much longer the Imperial Club website will be around. (link to larger printable version of available at bottom of page) The battery was recently charged, as it had been sitting for a while, I will re-checked voltage tomorrow now that it has set for a few days. Thanks for the link, I have some reading to do now.
