727 reverse band replaced, now hear clicking in reverse #2724546
12/16/19 04:50 PM
12/16/19 04:50 PM
WA
dwittig33 Offline OP
WA
Hi, I just replaced the reverse band in my 727 transmission on the 1976 power wagon, (the band had broke). Got it all back together and have two issues. I don't have park (which I've learned that I probably installed my park rod incorrectly) but also it clicks loudly when in reverse. I probably know more when i drop the pan again, but wanted to see if you guys had any advice. There is no clicking in drive. Thanks.
Dusty
Re: 727 reverse band replaced, now hear clicking in reverse [Re: dwittig33] #2724564
12/16/19 05:37 PM
12/16/19 05:37 PM
Dusty welcome aboard. I dont have a specific ans for you but the tranny guys will.
Re: 727 reverse band replaced, now hear clicking in reverse [Re: RapidRobert] #2724589
12/16/19 06:58 PM
12/16/19 06:58 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Both issues are probably the same. The click could be the park pawl trying to engage and will most likely go away when you install the rod correctly.
Re: 727 reverse band replaced, now hear clicking in reverse [Re: stumpy] #2724763
12/17/19 11:48 AM
12/17/19 11:48 AM
moparx Offline
moparx  Offline
welcome aboard dusty !
i believe stumpy is correct. if you re-install the park rod correctly, both problems will be fixed.
beer
Re: 727 reverse band replaced, now hear clicking in reverse [Re: moparx] #2724874
12/17/19 04:46 PM
12/17/19 04:46 PM
Guitar Jones Offline
How do you not install the park rod correctly and still get the shifter to move?
Re: 727 reverse band replaced, now hear clicking in reverse [Re: Guitar Jones] #2724876
12/17/19 04:53 PM
12/17/19 04:53 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
hammer
Re: 727 reverse band replaced, now hear clicking in reverse [Re: Guitar Jones] #2725108
12/18/19 12:48 PM
12/18/19 12:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Seen it many times. That's why it's a good idea to clock the snap ring so as to prevent this.
