Dist block or prop valve
#2724306
12/15/19 08:54 PM
12/15/19 08:54 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
My '70 Challenger has 4 wheel disc brakes so I'm hoping this is a distribution block and not a proportioning valve. Cass at DrDiff said it's a dist block so I just wanted to confirm that with you guys. He said if it was a prop valve it would have an adjustment nut on top. I do have a Wilwood prop valve on the rear brake line.
If you guys are unsure, I'm thinking I can take the plug out of the bottom and see if any parts fall out? It looks ALOT like the dist block shown on Inline Tube's website. Thanks.
Re: Dist block or prop valve
[Re: ProSport]
#2724323
12/15/19 09:47 PM
12/15/19 09:47 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
That is a block , not a prop valve .
[Re: Cab_Burge]
#2724336
12/15/19 10:56 PM
12/15/19 10:56 PM
ProSport
Akron, Ohio
Thanks guys!! Much appreciated.
[Re: dragon slayer]
#2724430
12/16/19 11:23 AM
12/16/19 11:23 AM
ProSport
Akron, Ohio
Which includes your brake warning light contact in case you develop a leak in the front or rear. Differential pressure moves plunger to ground your brake warning light. Ok thank you for the info.
[Re: dragon slayer]
#2724474
12/16/19 01:23 PM
12/16/19 01:23 PM
Posts: 1,211 Minn
SportF
Minn
Which includes your brake warning light contact in case you develop a leak in the front or rear. Differential pressure moves plunger to ground your brake warning light. AND slides over to cut off fluid to the low pressure (leaking) side. This is what gives you redundant brakes.
