Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: NachoRT74] #2725224
12/18/19 10:03 PM
12/18/19 10:03 PM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
[quote=NachoRT74]For "stock" look... all 4 corners the same. Easier for everything ( rotation, replacement, emergency, whatever )
I believe you and the others are right. I am wanting to make a fun car, but also want something a little stock appearing on the exterior and too wide of a rear tire might take that away from what I want. If I can think of the best wheel dimeter with that 275/6015 245/255 front, this might be much better setup for the car.
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: DoctorDiff] #2725226
12/18/19 10:05 PM
12/18/19 10:05 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Originally Posted by DoctorDiff
I recommend my 1.25" offset spring hanger/shackle kit, '68-'70 B-body rearend, 15 x 10" wheels with 5" backspacing and MT Sportsman SR 28/12/15 street radials.
So Cass, your saying that setup will bolt in, or will I need to weld spring perches in a new location? I do have a 1972 Roadrunner I would love to run larger, modern size wheels on.
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: Moparguy383] #2725227
12/18/19 10:07 PM
12/18/19 10:07 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Originally Posted by Moparguy383
I have a Dr. Diff offset spring hanger/shackle kit, '71 housing, 15 x 10 wheels with 5" backspacing and 325/50/15. Plenty of clearance.
Oh man, that looks tuff!
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: chargervert] #2725229
12/18/19 10:08 PM
12/18/19 10:08 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Originally Posted by chargervert
Migs,I have 295/50/15s on 15x10 Dragstars on my 73 Charger.
White in a Mopar is one of my favorite colors and that looks really good on yours.
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: migsBIG] #2725264
12/19/19 12:16 AM
12/19/19 12:16 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
If you run my offset hanger/shackle kit, you must install the spring perches at 44.75" on center.
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: mopardamo] #2725286
12/19/19 01:51 AM
12/19/19 01:51 AM
Cumberland, MD
Moparguy383 Offline
Moparguy383  Offline
Cumberland, MD
mopardamo,
I have super stock springs on it, that is all.
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: migsBIG] #2725399
12/19/19 03:39 PM
12/19/19 03:39 PM
Los Angeles, CA
JF_Moparts Offline
JF_Moparts  Offline
Los Angeles, CA
Mine's a Plymouth Satellite, but I run 255/45-17s all around.
Re: How big of a rear tire on you 1971-1974 Dodge Charger. [Re: JF_Moparts] #2725751
12/20/19 11:53 PM
12/20/19 11:53 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Thanks Cass. Too bad it isn’t a bolt in like e-bodies.
