kickdown rod #2723485
12/12/19 03:58 PM
12/12/19 03:58 PM
las vegas,nv
mopar muscle7271 Offline OP
las vegas,nv
hi,
is this rod for a 727 with a 383 or 440 from 60's?
https://www.ebay.com/itm/153754702228
Re: kickdown rod [Re: mopar muscle7271] #2723626
12/13/19 01:34 AM
12/13/19 01:34 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Just the part that runs down the backside of the engine to the pivot rod on the side of the transmission. Not sure exactly which year model, looks like the ones I have had on '67 Coronets with 318s?
It would still be missing the upper crank/pivot that attaches to the throttle bracket, and the carb to crank/pivot linkage rod, and the lower crank/pivot (transmission mounted) linkage rod that connects to the kickdown lever.
If you need a kickdown, and does not need to be original, the cable operated kickdown kits will work.
Re: kickdown rod [Re: 451Mopar] #2723636
12/13/19 03:40 AM
12/13/19 03:40 AM
las vegas,nv
las vegas,nv
ok this could possibly be a small block rod?
Re: kickdown rod [Re: 451Mopar] #2723762
12/13/19 03:04 PM
12/13/19 03:04 PM
las vegas,nv
las vegas,nv
rod measures 14 3/4" were 440 rods bigger or smaller then 383 rods?
Re: kickdown rod [Re: mopar muscle7271] #2724361
12/16/19 12:40 AM
12/16/19 12:40 AM
las vegas,nv
las vegas,nv
anyone have that middle rod for a 383? need right length rod to complete my set. it will goin a 72 plymouth duster with a 383
Re: kickdown rod [Re: mopar muscle7271] #2726008
12/22/19 04:25 AM
12/22/19 04:25 AM
las vegas,nv
las vegas,nv
??? anyone
Re: kickdown rod [Re: mopar muscle7271] #2726009
12/22/19 04:46 AM
12/22/19 04:46 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I think Year One sells parts for the kickdown linkage. Maybe check them out. work
Re: kickdown rod [Re: mopar muscle7271] #2726101
12/22/19 01:24 PM
12/22/19 01:24 PM
If I was you I would convert your motor to the Biuchilon kick down cable kit scope
Not the other cheaper one tsk
The early V8 cars came two ways, single piece and three piece kickdown linkage shruggy
Re: kickdown rod [Re: Cab_Burge] #2726127
12/22/19 02:35 PM
12/22/19 02:35 PM
moparx Online content
moparx  Online Content
say NO to lokar ! cheap, GM "fitzall" setup.
beer
Re: kickdown rod [Re: moparx] #2726289
12/23/19 12:27 AM
12/23/19 12:27 AM
las vegas,nv
las vegas,nv
lokar is better then the cheap off brand 30.00 cable. if i can find that one rod id have a set for 383 4 barrel
Re: kickdown rod [Re: mopar muscle7271] #2726290
12/23/19 12:27 AM
12/23/19 12:27 AM
las vegas,nv
las vegas,nv
can't believe no one has that rod on here
Re: kickdown rod [Re: mopar muscle7271] #2726291
12/23/19 12:37 AM
12/23/19 12:37 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Just because they have one doesn't mean they want to get rid of it. If you are having so much trouble finding one could be it's rare enough to hold on to.
Re: kickdown rod [Re: stumpy] #2726314
12/23/19 07:34 AM
12/23/19 07:34 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I have run that Bouchillon cable in the past and was happy with it.
Re: kickdown rod [Re: bobby66] #2726457
12/23/19 08:18 PM
12/23/19 08:18 PM
las vegas,nv
las vegas,nv
for how much one cost,i could get a used 3 piece set.
Re: kickdown rod [Re: mopar muscle7271] #2726574
12/24/19 11:52 AM
12/24/19 11:52 AM
if it were me, i would search out a used set before i went for lokar junk.
beer
Re: kickdown rod [Re: moparx] #2726610
12/24/19 01:20 PM
12/24/19 01:20 PM
las vegas,nv
las vegas,nv
only need one rod to complete my set,but i seen some decent price used sets.
Re: kickdown rod [Re: mopar muscle7271] #2726890
12/25/19 07:43 PM
12/25/19 07:43 PM
BlueRacer69 Offline
BlueRacer69  Offline
Have you looked around on E-bay? I see kick down linkages and sometimes single linkage rods on there all the time. Do a search for: Mopar Kickdown Linkage. Maybe you will find something.
Re: kickdown rod [Re: BlueRacer69] #2727337
12/27/19 11:46 AM
12/27/19 11:46 AM
IL
furious70 Offline
furious70  Offline
IL
FWIW, the earlier multi-piece BB kickdown stuff seems a little rare and $ anymore. I have 1 or 2 of them but have 0 interest in getting rid of them for that reason. I imagine many of the guys on here are like me. Later 70's stuff has a 1 piece kickdown that can work, but you have to change it all over.
70 Sport Fury
68 Charger
69 Coronet
72 RR
