Re: oil filter adapter
[Re: HotRodDave]
#2723434
12/12/19 12:11 PM
12/12/19 12:11 PM
Triple Threat
Renton Washington
Mine need some heat from a propane torch before I was able to get it out. I remember it fighting us a bit.
[Re: Fishstix]
#2723480
12/12/19 03:35 PM
12/12/19 03:35 PM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
I am trying to remember why, but I had an issue getting that sucker off. I remember having to use a set of really good vice grips. And, of course, a hammer. Am I off thinking not all of those adapters had the hex key? I will try to dig through my notes. No your not off, both of the 03 blocks I have here don't have the hex , the 6.1 I have is an 07 and it had the hex .
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
[Re: Ray408G3Hemi]
#2723580
12/12/19 09:23 PM
12/12/19 09:23 PM
Posts: 59 Charleston SC
Fishstix
Charleston SC
I am trying to remember why, but I had an issue getting that sucker off. I remember having to use a set of really good vice grips. And, of course, a hammer. Am I off thinking not all of those adapters had the hex key? I will try to dig through my notes. No your not off, both of the 03 blocks I have here don't have the hex , the 6.1 I have is an 07 and it had the hex . Mine was a 6.1 as well. Good grips, no heat, and few good hits with a hammer.
[Re: Fishstix]
#2723700
12/13/19 12:08 PM
12/13/19 12:08 PM
Posts: 421 montana
BANDIT
montana
The ‘09 I swapped out had the 12 mm hex inside. Went to NAPA and got a set of 1/2” drive impact Allen wrenches and a breaker bar and it came right out.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: HotRodDave]
#2723710
12/13/19 12:31 PM
12/13/19 12:31 PM
Ray408G3Hemi
Springtown Pa
03 07 04X2 05 11X2 and a don't remember. Not a one of them has a hex inside or out. Ric says the hex started with the change to 22X1.5mm oil filter, they have the Hex the 3/4-16 don't , My 6.1 block was changed over to 22mmx1.5mm...which is why that one has it.
[Re: HotRodDave]
#2723721
12/13/19 12:49 PM
12/13/19 12:49 PM
Posts: 935 Deland, Florida
biff426
Deland, Florida
I used a pipe wrench on the ones I have. These are actually standard thread on the block side so use a Derale one that accepts old school standard thread filters to get a better selection of filters.
