oil filter adapter #2723367
12/11/19 10:01 PM
12/11/19 10:01 PM
Kalispell Mt.
HotRodDave Offline OP
Happy Birthday HotRodDave  Offline OP
Kalispell Mt.
Any idea how to get the oil filter adapter/connector thingy out of a block without damaging it? Not the bot on angled one but the one that screws right in the block and filter screws right onto it. It is threaded on the outside and smooth and round inside.
Re: oil filter adapter [Re: HotRodDave] #2723376
12/12/19 12:52 AM
12/12/19 12:52 AM
Australia
L4staero Offline
L4staero  Offline
Australia
About half an inch up the oil cooler centre bolt is the hex for a 12mm Allen key to undo it
Re: oil filter adapter [Re: L4staero] #2723377
12/12/19 12:53 AM
12/12/19 12:53 AM
montana
BANDIT Offline
BANDIT  Offline
montana
Yup, what he said.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: oil filter adapter [Re: L4staero] #2723415
12/12/19 10:38 AM
12/12/19 10:38 AM
Charleston SC
Fishstix Offline
Fishstix  Offline
Charleston SC
I am trying to remember why, but I had an issue getting that sucker off. I remember having to use a set of really good vice grips. And, of course, a hammer. Am I off thinking not all of those adapters had the hex key? I will try to dig through my notes.
Re: oil filter adapter [Re: HotRodDave] #2723434
12/12/19 12:11 PM
12/12/19 12:11 PM
Renton Washington
Triple Threat Offline
Renton Washington
Mine need some heat from a propane torch before I was able to get it out. I remember it fighting us a bit.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: oil filter adapter [Re: L4staero] #2723456
12/12/19 01:46 PM
12/12/19 01:46 PM
Kalispell Mt.
Kalispell Mt.
I got 1/2 dozen hemis in the shop with the fitting I am talking about and none have a hex inside them or the flange like in that picture, they are totally round and smooth inside and threaded from one end to the other.
Re: oil filter adapter [Re: HotRodDave] #2723458
12/12/19 01:49 PM
12/12/19 01:49 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Will a large EZ out work?
68 Barracuda Formula S 340
Re: oil filter adapter [Re: Bad340fish] #2723468
12/12/19 02:42 PM
12/12/19 02:42 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Internal cam pipe wrench. Might have to measure to see if there is room for one to fit.
https://www.homedepot.com/p/Husky-Internal-Pipe-Wrench-Set-16PL0140/304217608
Re: oil filter adapter [Re: Bad340fish] #2723471
12/12/19 02:53 PM
12/12/19 02:53 PM
Kalispell Mt.
Kalispell Mt.
The heat combined with a large easy out did the trick, thanks guys, don't know why I didn't think of those.
Re: oil filter adapter [Re: Fishstix] #2723480
12/12/19 03:35 PM
12/12/19 03:35 PM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
No your not off, both of the 03 blocks I have here don't have the hex , the 6.1 I have is an 07 and it had the hex .
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: oil filter adapter [Re: Ray408G3Hemi] #2723481
12/12/19 03:36 PM
12/12/19 03:36 PM
Springtown Pa
Springtown Pa
Dave what year Block ?
1996 Viper GTS
Re: oil filter adapter [Re: Ray408G3Hemi] #2723493
12/12/19 04:33 PM
12/12/19 04:33 PM
Kalispell Mt.
Kalispell Mt.
03 07 04X2 05 11X2 and a don't remember. Not a one of them has a hex inside or out.
Re: oil filter adapter [Re: Ray408G3Hemi] #2723494
12/12/19 04:35 PM
12/12/19 04:35 PM
Kalispell Mt.
Kalispell Mt.
I'm putting a 14 BGE block with SRT rotating assembly and cam into an 11 Dodge 1500 with the eagle top end, the BGE block had the bolt on angle adapter thingy.
Re: oil filter adapter [Re: Ray408G3Hemi] #2723580
12/12/19 09:23 PM
12/12/19 09:23 PM
Charleston SC
Fishstix Offline
Fishstix  Offline
Charleston SC
Mine was a 6.1 as well. Good grips, no heat, and few good hits with a hammer.
Re: oil filter adapter [Re: Fishstix] #2723700
12/13/19 12:08 PM
12/13/19 12:08 PM
montana
BANDIT Offline
BANDIT  Offline
montana
The ‘09 I swapped out had the 12 mm hex inside. Went to NAPA and got a set of 1/2” drive impact Allen wrenches and a breaker bar and it came right out.
4600 DA
Re: oil filter adapter [Re: HotRodDave] #2723710
12/13/19 12:31 PM
12/13/19 12:31 PM
Springtown Pa
Springtown Pa
Ric says the hex started with the change to 22X1.5mm oil filter, they have the Hex the 3/4-16 don't , My 6.1 block was changed over to 22mmx1.5mm...which is why that one has it.
1996 Viper GTS
Re: oil filter adapter [Re: HotRodDave] #2723721
12/13/19 12:49 PM
12/13/19 12:49 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
I used a pipe wrench on the ones I have. These are actually standard thread on the block side so use a Derale one that accepts old school standard thread filters to get a better selection of filters.
