Correct A-Body Leaf Spring Front Hanger Bolt Size? #2723441
12/12/19 12:52 PM
12/12/19 12:52 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
For a 1970 Dart 340, should the rear leaf spring hanger attachment (forward attachment with 4-studs) be 1/2" or 5/8?
Re: Correct A-Body Leaf Spring Front Hanger Bolt Size? [Re: vinnyd76] #2723464
12/12/19 02:27 PM
12/12/19 02:27 PM
AndyF Offline
AndyF  Offline
Should be 5/8 with 340 springs but it could be either. Stuff gets changed after 50 years and who knows if the factory always did what it was supposed to do.
Re: Correct A-Body Leaf Spring Front Hanger Bolt Size? [Re: AndyF] #2723635
12/13/19 03:18 AM
12/13/19 03:18 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Factory correct for A, B, C, E bodies with V-8 engines.
Re: Correct A-Body Leaf Spring Front Hanger Bolt Size? [Re: kentj340] #2723761
12/13/19 03:00 PM
12/13/19 03:00 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Agree with the aboves.
A good break down of most of the springs/bushing combos.
http://www.stengelbros.com/suspensi.../dodge-lancer-dart-swinger-leaf-springs/
https://www.stengelbros.net/RB-60-Rubber-Bushing-2-OD-%C2%A0-58-ID-25-Length-3125-Overall-Length_p_6861.html
https://www.stengelbros.net/Rubber-Bushings_c_411.html
