The primary purpose of a damper is to (attempt to) suppress destructive harmonic forces (not balance related). The exact design is highly dependent on the engine design and use (not the power developed), especially crankshaft stiffness. A stroker is not a stiff as a stock crank, etc.
Boffin Emeritus
