oil filter adapter
#2723367
12/11/19 10:01 PM
12/11/19 10:01 PM
Posts: 12,406 Kalispell Mt.
HotRodDave
Kalispell Mt.
Any idea how to get the oil filter adapter/connector thingy out of a block without damaging it? Not the bot on angled one but the one that screws right in the block and filter screws right onto it. It is threaded on the outside and smooth and round inside.
Re: oil filter adapter
[Re: HotRodDave]
#2723434
12/12/19 12:11 PM
12/12/19 12:11 PM
Triple Threat
Renton Washington
Mine need some heat from a propane torch before I was able to get it out. I remember it fighting us a bit.
[Re: L4staero]
#2723456
12/12/19 01:46 PM
12/12/19 01:46 PM
HotRodDave
Kalispell Mt.
I got 1/2 dozen hemis in the shop with the fitting I am talking about and none have a hex inside them or the flange like in that picture, they are totally round and smooth inside and threaded from one end to the other.
[Re: HotRodDave]
#2723458
12/12/19 01:49 PM
12/12/19 01:49 PM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
Will a large EZ out work?
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: Bad340fish]
#2723471
12/12/19 02:53 PM
12/12/19 02:53 PM
HotRodDave
Kalispell Mt.
The heat combined with a large easy out did the trick, thanks guys, don't know why I didn't think of those.
[Re: Fishstix]
#2723480
12/12/19 03:35 PM
12/12/19 03:35 PM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
I am trying to remember why, but I had an issue getting that sucker off. I remember having to use a set of really good vice grips. And, of course, a hammer. Am I off thinking not all of those adapters had the hex key? I will try to dig through my notes. No your not off, both of the 03 blocks I have here don't have the hex , the 6.1 I have is an 07 and it had the hex .
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
[Re: Ray408G3Hemi]
#2723493
12/12/19 04:33 PM
12/12/19 04:33 PM
HotRodDave
Kalispell Mt.
03 07 04X2 05 11X2 and a don't remember. Not a one of them has a hex inside or out.
[Re: Ray408G3Hemi]
#2723494
12/12/19 04:35 PM
12/12/19 04:35 PM
HotRodDave
Kalispell Mt.
I'm putting a 14 BGE block with SRT rotating assembly and cam into an 11 Dodge 1500 with the eagle top end, the BGE block had the bolt on angle adapter thingy.
[Re: Ray408G3Hemi]
#2723580
12/12/19 09:23 PM
12/12/19 09:23 PM
Posts: 58 Charleston SC
Fishstix
Charleston SC
I am trying to remember why, but I had an issue getting that sucker off. I remember having to use a set of really good vice grips. And, of course, a hammer. Am I off thinking not all of those adapters had the hex key? I will try to dig through my notes. No your not off, both of the 03 blocks I have here don't have the hex , the 6.1 I have is an 07 and it had the hex . Mine was a 6.1 as well. Good grips, no heat, and few good hits with a hammer.
[Re: Fishstix]
#2723700
12/13/19 12:08 PM
12/13/19 12:08 PM
Posts: 421 montana
BANDIT
montana
The ‘09 I swapped out had the 12 mm hex inside. Went to NAPA and got a set of 1/2” drive impact Allen wrenches and a breaker bar and it came right out.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: HotRodDave]
#2723710
12/13/19 12:31 PM
12/13/19 12:31 PM
Ray408G3Hemi
Springtown Pa
03 07 04X2 05 11X2 and a don't remember. Not a one of them has a hex inside or out. Ric says the hex started with the change to 22X1.5mm oil filter, they have the Hex the 3/4-16 don't , My 6.1 block was changed over to 22mmx1.5mm...which is why that one has it.
[Re: HotRodDave]
#2723721
12/13/19 12:49 PM
12/13/19 12:49 PM
Posts: 935 Deland, Florida
biff426
Deland, Florida
I used a pipe wrench on the ones I have. These are actually standard thread on the block side so use a Derale one that accepts old school standard thread filters to get a better selection of filters.
