Best thread sealer for header bolts BB #2722911
12/10/19 11:07 AM
12/10/19 11:07 AM
Az
69hemibeep Offline OP
Az
What do you guys use for the holes that go into the water jacket?
1969 Hemi Roadrunner 2nd owner
Re: Best thread sealer for header bolts BB [Re: 69hemibeep] #2722912
12/10/19 11:08 AM
12/10/19 11:08 AM
an8sec70cuda Offline
Teflon paste like Permatex.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Best thread sealer for header bolts BB [Re: 69hemibeep] #2722913
12/10/19 11:12 AM
12/10/19 11:12 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Studs with Teflon pipe thread sealer has always worked for me.
Re: Best thread sealer for header bolts BB [Re: an8sec70cuda] #2722932
12/10/19 12:37 PM
12/10/19 12:37 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
This has worked for me as well.
As mentioned, you will get much more reliable sealing with studs vs. bolts.
I can attest that they make fitting headers more challenging on a BB B-body, but it can be done.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Best thread sealer for header bolts BB [Re: wingman] #2722946
12/10/19 01:19 PM
12/10/19 01:19 PM
moparx Offline
moparx  Offline
loctite 567 teflon paste here.
beer
Re: Best thread sealer for header bolts BB [Re: moparx] #2722947
12/10/19 01:24 PM
12/10/19 01:24 PM
Az
Az
This is for bolts not studs right?
Re: Best thread sealer for header bolts BB [Re: 69hemibeep] #2722950
12/10/19 01:32 PM
12/10/19 01:32 PM
moparx Offline
moparx  Offline
both. the loctite works for all threaded fittings.
beer
Re: Best thread sealer for header bolts BB [Re: moparx] #2722967
12/10/19 02:10 PM
12/10/19 02:10 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
For my manifold studs I used Loctite 577 along with the 7649 activator. Tried all regular autopart store sealant items, none worked. Got the 577 from Grainger.
Re: Best thread sealer for header bolts BB [Re: njmopar] #2723067
12/10/19 07:47 PM
12/10/19 07:47 PM
Az
Az
Re: Best thread sealer for header bolts BB [Re: 69hemibeep] #2723132
12/10/19 11:50 PM
12/10/19 11:50 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Teflon tape.
Re: Best thread sealer for header bolts BB [Re: Exit1965] #2723145
12/11/19 12:54 AM
12/11/19 12:54 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Masters metallic pipe dope.
Re: Best thread sealer for header bolts BB [Re: Uberpube] #2723360
12/11/19 09:29 PM
12/11/19 09:29 PM
85086
moparpollack Online penguin-006
Lil Herman
moparpollack  Online Penguin-006
Lil Herman
85086
Stealth heads! Otherwise I used Indianhead sealant.
Re: Best thread sealer for header bolts BB [Re: moparpollack] #2723645
12/13/19 07:50 AM
12/13/19 07:50 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
The Permatex copper colored stuff always worked for me.
Re: Best thread sealer for header bolts BB [Re: 70HemiGTX] #2725039
12/18/19 08:15 AM
12/18/19 08:15 AM
Rochester, PA (near Pittsburgh...
1974 474 Duster Offline
Stupid question, how many or which studs actually go into the water jackets on a cast head????
Ken
Re: Best thread sealer for header bolts BB [Re: 1974 474 Duster] #2725140
12/18/19 02:43 PM
12/18/19 02:43 PM
All of them on stock BB production headsscope
Re: Best thread sealer for header bolts BB [Re: Cab_Burge] #2725144
12/18/19 03:02 PM
12/18/19 03:02 PM
Okay that's what I was thinking. Have not messed w/stock cast heads on an Rb in 20 years. Will clean all the bolts up & put a little Teflon paste on them.
Thanks so much!!!
Re: Best thread sealer for header bolts BB [Re: 1974 474 Duster] #2725439
12/19/19 07:00 PM
12/19/19 07:00 PM
On a side note I would suggest useing the double end shouldered (stock type) studs & you can trim the outer fine threaded end to ease header fitment. You only need enough threads so the nut will fit flush when tightened & any more hampers fitment.
