Remove clock knob? #2722920
12/10/19 11:53 AM
12/10/19 11:53 AM
Minn
SportF Offline OP
SportF  Offline OP
Minn
How to remove a clock knob from a '63 Plymouth B body dash. I know the shaft is threaded, but isn't there a collar, shaft, and a knob? Please advise. Thanks
Re: Remove clock knob? [Re: SportF] #2722972
12/10/19 02:16 PM
12/10/19 02:16 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
There is a "small" sleeve nut in the center of the knob,if the shaft is intact and the threaded end not broken,it's self explanatory..
Re: Remove clock knob? [Re: SportF] #2722999
12/10/19 03:28 PM
12/10/19 03:28 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
is easier to note being dissasembled... then you'll figure it out!
hold the exterior piece ( knob itself ) while unscrewing the center nut with a tiny screwdriver
Re: Remove clock knob? [Re: NachoRT74] #2723017
12/10/19 04:12 PM
12/10/19 04:12 PM
Minn
SportF Offline OP
SportF  Offline OP
Minn
Well, there it is. Thanks gang.
