Best thread sealer for header bolts BB
#2722911
12/10/19 11:07 AM
12/10/19 11:07 AM
Posts: 1,379 Az
69hemibeep
Az
What do you guys use for the holes that go into the water jacket?
1969 Hemi Roadrunner 2nd owner
Re: Best thread sealer for header bolts BB
[Re: 69hemibeep]
#2722912
12/10/19 11:08 AM
12/10/19 11:08 AM
Posts: 13,345 Marion, South Carolina [><]
an8sec70cuda
Teflon paste like Permatex.
[Re: an8sec70cuda]
#2722932
12/10/19 12:37 PM
12/10/19 12:37 PM
Posts: 3,370 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Teflon paste like Permatex. This has worked for me as well. As mentioned, you will get much more reliable sealing with studs vs. bolts. I can attest that they make fitting headers more challenging on a BB B-body, but it can be done.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: moparx]
#2722947
12/10/19 01:24 PM
12/10/19 01:24 PM
Posts: 1,379 Az
69hemibeep
Az
This is for bolts not studs right?
[Re: moparx]
#2722967
12/10/19 02:10 PM
12/10/19 02:10 PM
Posts: 1,331 Clinton, NJ
njmopar
Clinton, NJ
For my manifold studs I used Loctite 577 along with the 7649 activator. Tried all regular autopart store sealant items, none worked. Got the 577 from Grainger.
[Re: Uberpube]
#2723360
12/11/19 09:29 PM
12/11/19 09:29 PM
moparpollack
Lil Herman
Lil Herman
85086
Stealth heads! Otherwise I used Indianhead sealant.
[Re: 1974 474 Duster]
#2725439
12/19/19 07:00 PM
12/19/19 07:00 PM
RapidRobert
On a side note I would suggest useing the double end shouldered (stock type) studs & you can trim the outer fine threaded end to ease header fitment. You only need enough threads so the nut will fit flush when tightened & any more hampers fitment.
