2001 dodge ram compressor #2720205
11/29/19 08:50 AM
11/29/19 08:50 AM
Hamburg, Pa.
72 RR DUDE Offline OP
Hamburg, Pa.
There is a problem with my air condition and I,m planning on getting it fixed in spring. Currently when i put the defroster on the compressor keeps kicking on and off. Would it cause a problem to pull the fuse for the winter so it stops kicking on and off?????
Re: 2001 dodge ram compressor [Re: 72 RR DUDE] #2720212
11/29/19 09:55 AM
11/29/19 09:55 AM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
system is designed to do that. it fast cycles because it is low on freon. fix leak and it should stop fast cycle. compressors were locking up over winter before that so they designed it to keep compressors turning to prevent lockup.
Re: 2001 dodge ram compressor [Re: rbkt65] #2721586
12/05/19 08:36 AM
12/05/19 08:36 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
.....it also helps dry the air which aids in a faster defrost.
If it’s never had a compressor that era was famous for leaking out the front seal as a vapor which was very hard to detect. It didn’t leak bad, but often required a yearly service.
Re: 2001 dodge ram compressor [Re: J_BODY] #2722852
12/10/19 12:17 AM
12/10/19 12:17 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
As stated above it's low on Freon. If it's the first time it may have a very slow leak. Recharge and see if problem happens again. The clicking means it's just at the point were the system cuts out for low Freon.
