Page 3 of 3 1 2 3
Re: Assassin bars. [Re: HOTMOPR] #2722713
12/09/19 10:10 AM
12/09/19 10:10 AM
an8sec70cuda Offline
FWIW...I'm on my second pair of mono leaf springs on my cuda. Bent the first set a few years back. Some of you may remember a member here by the handle "TheOtherDodge" who had a badass red '73 challenger, 499" big block on nitrous running low 9s. He bent springs on his w/ Cal-Tracs if I recall correctly before he switched to ladder bars.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Assassin bars. [Re: an8sec70cuda] #2722772
12/09/19 04:03 PM
12/09/19 04:03 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I'd think that adding a short leaf section where the CalTrac link pushes down on the spring would add enough stiffness in that high-load area to help resist that bending problem.
Re: Assassin bars. [Re: BradH] #2722930
12/10/19 12:23 PM
12/10/19 12:23 PM
VA Beach, VA
Runnoft Offline
Runnoft  Offline
VA Beach, VA
On my other car I run Assassin bars with the SRC spring perches and Calvert Split Mono Leafs. The extra adjustments are nice but honestly I've never moved them since setting it up. The only thing I adjust is preload to keep the car going straight. I've been fast with them. Really fast.
Cruiser: 66 Dodge Coronet 500, Indy SR 440, Gen 7 Accel EFI = 11.38 @ 116.
Racing: Brand X, X275 Procharged Smallblock on M1, Leafsprings, Holley EFI = 4.30 @ 168
Re: Assassin bars. [Re: BradH] #2723127
12/10/19 11:32 PM
12/10/19 11:32 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Agreed. I used to clamp flat stock to the rear leaf segment of my car to keep the springs from bending. Took the clamps off for street driving and immediatley bent the longest spring forward of the rear hanger. 4 speeds are hard on stock springs!
Re: Assassin bars. [Re: Jeremiah] #2723184
12/11/19 09:30 AM
12/11/19 09:30 AM
Now that I think of it...when mine bent, it was the rear half on the driver's side that bent...not the front section.
CHIP
Re: Assassin bars. [Re: an8sec70cuda] #2723194
12/11/19 10:22 AM
12/11/19 10:22 AM
BradH Offline
BradH  Offline
Is that part of what rear spring mount sliders are designed to help with?
I don't see how that sort of issue would be any different between CalTracs and Assassin bars, but I can see how bending the spring behind the front eye could result from CalTracs.
Re: Assassin bars. [Re: BradH] #2723206
12/11/19 11:05 AM
12/11/19 11:05 AM
I'm not sure about sliders helping w/ it or not? It definitely wouldn't be any different b/t the two styles of bars as far as bending the rear halves.
Looking at the two designs, I don't really see how the Assassin bars would be any less prone to bending the front half of the spring?
CHIP
Re: Assassin bars. [Re: an8sec70cuda] #2723218
12/11/19 12:30 PM
12/11/19 12:30 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Maybe more so, IIRC you have to drill a hole in the leaf to mount the front pivot bracket with the Smiths stuff. shruggy.
Re: Assassin bars. [Re: Tig] #2723224
12/11/19 12:48 PM
12/11/19 12:48 PM
BradH Offline
BradH  Offline
I wasn't a great Physics student, but I'd a$$ume how the Assassin bar bracket clamps to the front leaf behind the spring eye distributes the load across a wider area of the leaf spring than the CalTrac "bolt" that pushes down in more of a point-loaded fashion. That's why I mentioned that a short leaf section clamped in that same area for a CalTracs-equipped car could help achieve the same thing.
Re: Assassin bars. [Re: BradH] #2723243
12/11/19 01:42 PM
12/11/19 01:42 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Ya the bracket distributes the pressure across a wider area.
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Assassin bars. [Re: HOTMOPR] #2723259
12/11/19 03:24 PM
12/11/19 03:24 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Just talked to Digby. They have never bent to a set of springs. The have only broken the lockdown bolt. That's well over a 2000 pony combo..
Re: Assassin bars. [Re: HOTMOPR] #2723317
12/11/19 06:25 PM
12/11/19 06:25 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Well there you go, I trust what they say !!!!
Re: Assassin bars. [Re: CSK] #2723320
12/11/19 06:37 PM
12/11/19 06:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
And I would bet that it spins before it hooks up a dead hook applies more torque
wave
Re: Assassin bars. [Re: MR_P_BODY] #2723326
12/11/19 07:02 PM
12/11/19 07:02 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
wave
it's a ET street drag radial tire.. It better dead hook or your fooked.
Re: Assassin bars. [Re: HOTMOPR] #2723397
12/12/19 09:18 AM
12/12/19 09:18 AM
wave
iagree You HAVE to dead hook a radial. Once they spin, it's done.
CHIP
Re: Assassin bars. [Re: OhioMopar] #2725342
12/19/19 10:43 AM
12/19/19 10:43 AM
Mt.Gilead, Ohio
OhioMopar Offline OP
Mt.Gilead, Ohio
Wow, this thread really took off, and became a sales ad and critique of how great Cal-tracs are! Lol. Thanks to all that answered my questions. I have my Assassin bars and should be installing them tomorrow. I'll see how they like the springs that are on it before I jump to a monoleaf setup.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Page 3 of 3 1 2 3
