Page 33 of 48 1 2 31 32 33 34 35 47 48
Re: Modern Bullitt build [Re: T2R9] #2720562
12/01/19 06:26 AM
12/01/19 06:26 AM
Virginia
larry4406 Online content
larry4406  Online Content
Virginia
Originally Posted by T2R9
Wow,nice work! This whole build is perfection!
Agreed, simply stunning work quality and photography.
Keep it up Pat!
Re: Modern Bullitt build [Re: larry4406] #2722413
12/07/19 09:53 PM
12/07/19 09:53 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Only 1 spot for a temperature sender on this gen3 Hemi, and I need two, 1 for the fuel injection and 1 for the gauge. I had to remove a freeze plug and make a plate that I could drill for an additional temperature sender.
I also have all of the wiring set and ready to enter and pass through the firewall through a split grommet. This will allow all of the plug-in connectors to pass through a single 2 1/4ā€ hole hidden just above the transmission.
Pat
[Linked Image]post pictures
Re: Modern Bullitt build [Re: Keepat] #2722465
12/08/19 08:35 AM
12/08/19 08:35 AM
Virginia
Virginia
Pat - very clever solution to adding another temperature port! Excellent work and photo's as well.
Re: Modern Bullitt build [Re: larry4406] #2722471
12/08/19 09:28 AM
12/08/19 09:28 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank you sir!
Re: Modern Bullitt build [Re: Keepat] #2722668
12/08/19 11:40 PM
12/08/19 11:40 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Engine is installed (I hope for the last time;-)
Pat
[Linked Image]images free hosting
[Linked Image]upload picture without account
[Linked Image]pic upload
Re: Modern Bullitt build [Re: Keepat] #2722672
12/08/19 11:54 PM
12/08/19 11:54 PM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
That's awesome! Very nice work! You should be extremely pleased. -Trent
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Modern Bullitt build [Re: Keepat] #2722696
12/09/19 07:56 AM
12/09/19 07:56 AM
Medford OR
FrankenScamp Offline
Medford OR
Lots of progress lately....very cool!
Looks great. bow
Re: Modern Bullitt build [Re: FrankenScamp] #2722699
12/09/19 08:23 AM
12/09/19 08:23 AM
Chicago
rocksmopar Online content
rocksmopar  Online Content
Chicago
Love the body lift you are using..
Looking for affordable 72-74 Cuda parts
Re: Modern Bullitt build [Re: MadMopars] #2725713
12/20/19 07:50 PM
12/20/19 07:50 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Trent,
It is definitely the part of the build
Thank you!
Pat
Re: Modern Bullitt build [Re: FrankenScamp] #2725714
12/20/19 07:51 PM
12/20/19 07:51 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Looks great. bow
Thank you!
Re: Modern Bullitt build [Re: rocksmopar] #2725715
12/20/19 07:55 PM
12/20/19 07:55 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Yes, a must have for the middle aged ;-)
Re: Modern Bullitt build [Re: Keepat] #2725716
12/20/19 07:55 PM
12/20/19 07:55 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Moving along with a few projects! All the fuel, AC, and Hydroboost lines hooked up! Trans cross member and shifter is installed.
Pat
[Linked Image]i want you forever
[Linked Image]photoupload
[Linked Image]pic sharing
Re: Modern Bullitt build [Re: Keepat] #2727001
12/26/19 10:10 AM
12/26/19 10:10 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Emergency brake cables installed using a small stainless steel roller that I got from West Marine. It guide the E brake cable after it passes through the sub frame connector.
Pat
[Linked Image]upload free photos
Re: Modern Bullitt build [Re: Keepat] #2727506
12/27/19 08:43 PM
12/27/19 08:43 PM
Superfreak
Superfreak
I can honestly say that the quality of your work is absolutely outstanding!!!
Re: Modern Bullitt build [Re: ] #2727604
12/28/19 09:26 AM
12/28/19 09:26 AM
Virginia
Virginia
Agreed! I think this is one of the best builds out here on net.
Re: Modern Bullitt build [Re: larry4406] #2728175
12/29/19 11:55 PM
12/29/19 11:55 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank you gentlemen!
Not a fun weekend installing the rear glass and trim. AMD glass was not a problem but fitting the trim took two or three times to get everything just right. Fortunately no chips or scratches just a lot less hair on my head ;-)
Pat
[Linked Image]image sharing
Re: Modern Bullitt build [Re: Keepat] #2730147
01/05/20 12:14 AM
01/05/20 12:14 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Car is ready for fuel! Had to make a tool for the original theft proof fasteners.
Pat
[Linked Image]photo hosting site free
[Linked Image]old sawmill cafe
Re: Modern Bullitt build [Re: Keepat] #2730626
01/06/20 08:14 PM
01/06/20 08:14 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Weld Mount is in acrylic adhesive mounting system with a wide variety of very cool fasteners. We use it on the boats when we cannot drill into a bulkhead, fuel tank, or hull sides to mount or fasten equipment and wires. I used it to mount a few fan relays and headlight door operator To keep the engine bay clean of fasteners. Very cool stuff, easy to use an extremely strong!
Pat
http://weldmountsystems.com/
[Linked Image]free image url
common american girl first names
Re: Modern Bullitt build [Re: Keepat] #2730680
01/06/20 11:39 PM
01/06/20 11:39 PM
Medford OR
Medford OR
Iā€™m going to start saving up now, for a plane ticket to Maryland to see this car when it is done.
Thanks, again, for the update. Cheers. šŸ‘
Re: Modern Bullitt build [Re: FrankenScamp] #2730869
01/07/20 05:45 PM
01/07/20 05:45 PM
Virginia
Virginia
I know I want to see it and thank god I am only one state away!
