wiw 273 with 340 parts #2722607
12/08/19 05:26 PM
12/08/19 05:26 PM
TB3CUDA Offline OP
TB3CUDA  Offline OP
looking at a 67 273 engine,has 340 exhaust manifolds,340 intake and carb w/air cleaner,482 bellhousing with cover, also has dual point dist ,wiw in parts.motor runs.
Re: wiw 273 with 340 parts [Re: TB3CUDA] #2722752
12/09/19 01:20 PM
12/09/19 01:20 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Did it start life as a 273-235 or was it a 2 bbl motor? If it was a 4bbl motor maybe $600.00. If you part it out maybe more, but its slow dollars.
Re: wiw 273 with 340 parts [Re: formula_s] #2722767
12/09/19 02:39 PM
12/09/19 02:39 PM
TB3CUDA Offline OP
TB3CUDA  Offline OP
original 4 barrel motor
Re: wiw 273 with 340 parts [Re: TB3CUDA] #2722794
12/09/19 05:40 PM
12/09/19 05:40 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
You won't have any trouble selling the exhaust manifolds for 500.00 to 600.00 for the pair.
Re: wiw 273 with 340 parts [Re: 318 Stroker] #2722846
12/09/19 10:30 PM
12/09/19 10:30 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Looks like a money maker to me.
The exhaust manifolds as mentioned $
273 Power Pak motor should have adjustable rockers.
Flywheel, bellhousing, air cleaner, 4v intake, could be good carb number, and so on and so on.
I see $1000.00 easy
Re: wiw 273 with 340 parts [Re: mccannix] #2722878
12/10/19 07:04 AM
12/10/19 07:04 AM
TB3CUDA Offline OP
TB3CUDA  Offline OP
ended up buying it.coolest thing i found is the knife handle oil dip stick,never seen one before
Re: wiw 273 with 340 parts [Re: TB3CUDA] #2722965
12/10/19 01:02 PM
12/10/19 01:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: wiw 273 with 340 parts [Re: stumpy] #2723181
12/11/19 08:28 AM
12/11/19 08:28 AM
Ontario, Canada
GVH Offline
GVH  Offline
Ontario, Canada
all early 273 's had adjustable rockers
B Body Air Cleaner with Lid
by 440whiteboy. 01/17/20 07:59 AM
62 Chrysler 300 - $13,500
by not_a_charger. 01/17/20 06:36 AM
77 Chevy LUV - $2,600
by not_a_charger. 01/17/20 06:33 AM
74 Gold Duster - $13,500
by not_a_charger. 01/17/20 06:32 AM
Moparts Recent Posts
Your 411 on NHRA all access ?
by Gavin. 01/17/20 07:50 AM
Hemi Carburetor Linkage rod and swivel ???
by dragon slayer. 01/17/20 07:49 AM
Hemi Fuel Pump Push rod difference??
by dragon slayer. 01/17/20 07:42 AM
