Re: The new bullet
[Re: dvw]
#2722528
12/08/19 12:54 PM
12/08/19 12:54 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Te me about the milling between the intake lifter bores. I'm assuming they may have been moved over but why mill the outside? Doug .. . A few extra steps have been taken to remove weight out of the block that is what we are looking at here...
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: The new bullet
[Re: TRENDZ]
#2722530
12/08/19 12:57 PM
12/08/19 12:57 PM
WHITEDART
bean town ....Ca
My guess on the valley machining is that the block is cast for both 59°& 48° lifter locations. Looks like lightening is the only purpose. ... Yes you are correct . The lifters are stood up even a little straighter in this block we are at 47゚...
Re: The new bullet
[Re: Biginchmopar]
#2723714
12/13/19 12:35 PM
12/13/19 12:35 PM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
Nothing to see here .937" Holes? Beautiful thing isn't .......................I have aquestion, could you use cartridge lifters in this block?
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
Re: The new bullet
[Re: 340Cuda]
#2723996
12/14/19 02:39 PM
12/14/19 02:39 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
have you ever considered a p-5? Do you mean R5/P7 as in old NASCAR engines? No, Pro Stock truck head.
Re: The new bullet
[Re: Ody1003]
#2724013
12/14/19 04:06 PM
12/14/19 04:06 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
Seems to me a 47-degree could use a 48-degree core. Cam grinder may whine a bit but I'm sure it's all sorted out ahead of time. Question,thought 48" cams were a little tough to get, now at 47" degrees. Just curious. Thanks, awesome effort keep us updated.
Re: The new bullet
[Re: Ody1003]
#2724144
12/15/19 11:11 AM
12/15/19 11:11 AM
WHITEDART
bean town ....Ca
Question,thought 48" cams were a little tough to get, now at 47" degrees. Just curious. Thanks, awesome effort keep us updated. brett has 30 cores that could go as big as a 565 lobe in 47 or 48*.pick your poison
Re: The new bullet
[Re: scottb]
#2724213
12/15/19 03:26 PM
12/15/19 03:26 PM
WHITEDART
bean town ....Ca
Bullit has 50mm cam cores they cut a 2.00 core down to the 50mm that is like 1.966 something like that size they just cut one down for me last summer 48 or 59 ??
Re: The new bullet
[Re: justinp61]
#2724294
12/15/19 08:25 PM
12/15/19 08:25 PM
Posts: 3,508 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
have you ever considered a p-5? Do you mean R5/P7 as in old NASCAR engines? No, Pro Stock truck head. Duh, I should have known that!
Re: The new bullet
[Re: BradH]
#2725938
12/21/19 07:04 PM
12/21/19 07:04 PM
WHITEDART
bean town ....Ca
Would a been used for oiling.. But beings how we have roller bearings they will do nothing but be along for the ride.. Got to use my friends laser tool.. Man did it make for an easy set up when mapi now the camshaft
