Page 1 of 3 1 2 3
issues with fresh 440 #2722389
12/07/19 07:46 PM
12/07/19 07:46 PM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
rebuilt '78 with diamond pistons,pep rods, eddy heads,crane roller rockers,Comp Cams 509 with Comp lifters.
I rebuilt this engine and everything went as smooth as silk. Primed the oil system and had 80PSI oil pressure. Installed it in the car etc.etc. Did the break in procedure with 10 w 30 and Comp break in additive all good. I noticed after break in the valve train was a little loud but not alarmingly loud. I changed oil to 10 w 40 and another bottle of additive. noticed oil pressure took longer then I liked to reach the top,about 30 seconds. shut down and restart it and would get about 30 psi on the gauge. shut it down and restart it and it would instantly jump to 80 and stay there until the next day.same thing all over again. decided to change back to amsoil z rod 10 w 30 and a new filter and oil pressure did the same thing but was faster to get up top.
Now with the new 10w 30 when the engine reaches temp I'm getting a loud clacking noise up top as far as I can tell. I readjusted the rocker's with a quarter turn from zero lash and fired it up again. cold the engine has no noise but when it reaches temp the clacking is back. lower rpm's to 500 and it get's quiet,raise it to 1000 and it's loud fast paced clack. I tore the top end off but lifter's are not scored but I'm no expert on the cam lobes to see if the wear is normal for a fresh cam. any idea's? Bad lifter maybe?
Re: issues with fresh 440 [Re: stinger] #2722391
12/07/19 08:03 PM
12/07/19 08:03 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Did you cut the filter apart. It’s a very good thing to do after cam break in.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: issues with fresh 440 [Re: pittsburghracer] #2722392
12/07/19 08:08 PM
12/07/19 08:08 PM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
would some fine metallic paste be normal in a fresh engine? I was told it was
Re: issues with fresh 440 [Re: stinger] #2722396
12/07/19 08:28 PM
12/07/19 08:28 PM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
Pics
Re: issues with fresh 440 [Re: stinger] #2722399
12/07/19 08:38 PM
12/07/19 08:38 PM
Casper, WY
W
Wax Offline
Wax  Offline
W
Casper, WY
It appears from the picture that you are losing the lobes on the cam shaft. What did you use for break in oil?
Re: issues with fresh 440 [Re: Wax] #2722403
12/07/19 08:48 PM
12/07/19 08:48 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Hard to tell by looking at a pic on my phone, but I don’t see anything alarming on the cam.
Pull each lifter and carefully inspect the bottom of it.
When cam lobes go bad, the lifters almost always go with them.
With as little run time as it has, the lifters should be perfect.
If you see something iffy on one, carefully inspect the corresponding cam lobe.
Did you check for lifter rotation during assembly?
What are the open and closed spring loads?
What did you use for cam lube?
Re: issues with fresh 440 [Re: fast68plymouth] #2722406
12/07/19 09:05 PM
12/07/19 09:05 PM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
Lifters look good
Springs are what came on the rpm’
Molly paste
Re: issues with fresh 440 [Re: stinger] #2722408
12/07/19 09:09 PM
12/07/19 09:09 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Re: issues with fresh 440 [Re: CSK] #2722411
12/07/19 09:30 PM
12/07/19 09:30 PM
PA.
"Little"John
"Little"John
PA.
Is it the camera flash or shop lighting that makes some of the lobes look shinier than others?
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: issues with fresh 440 [Re: pittsburghracer] #2722430
12/07/19 11:36 PM
12/07/19 11:36 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
Don't know what to tell you about the valve train. If that is is a Comp Extreme Energy or what ever they call their most aggressive lobe profile hydraulic cam, they are noted for being noisy.
The only things I can think of besides a FUBAR oil filter that can make oil pressure come and go like that is a sticking relief valve or a spun pump drive that is now using friction to turn the pump.
If you changed the pump when you built the engine, did you disassemble it and clean it? It's amazing the machining trash you will find inside a new oil pump that can jam the rotors and twist the drive or hang the bypass.
Kevin
Re: issues with fresh 440 [Re: Twostick] #2722481
12/08/19 10:25 AM
12/08/19 10:25 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I was under the belief that once a lobe on a cam has wear across the whole lobe, its gone. Lifters are ground with a taper/crown. In that pic you can clearly see wear the whole way across a lobe. I think the cam is going flat. I would go back to the lifter/s and see if a tightening up quiets them down, although it sounds like you already did this once. If you have a dial indicator you could check lift off the top of a pushrod to see if its off the mark.
Re: issues with fresh 440 [Re: B1MAXX] #2722483
12/08/19 10:29 AM
12/08/19 10:29 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
After a second look at the pictures, also looks petty dry up top for a just run engine. I would think that all the crevices/depressions would be full of puddles of oil. shruggy
Re: issues with fresh 440 [Re: B1MAXX] #2722501
12/08/19 11:44 AM
12/08/19 11:44 AM
So. Burlington, Vt.
So. Burlington, Vt.
The nose of the cam lobes will have contact all the way across.
It’s extremely unlikely all the lobes are going flat, so turn the motor over by hand so you can inspect the nose of each lobe.
You’re looking for one that’s obviously different than the others.
To address the oil pressure, I agree with pulling the pump all apart, clean and inspect.
Actually, before you pulled the pump, you could remove and inspect how smoothly the relief valve slides in its bore.
As for the noise, I think you’d be better off with more preload.
1/2 to 1 turn....... depending on the thread pitch of the adjuster screw.
I’d be shooting for .030-.040 preload.
Re: issues with fresh 440 [Re: fast68plymouth] #2722553
12/08/19 02:02 PM
12/08/19 02:02 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
1/4 turn isn't near enough pre-load on the tappets.
Re: issues with fresh 440 [Re: lewtot184] #2722556
12/08/19 02:17 PM
12/08/19 02:17 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
iagree at a 24 thread that's roughly .010 - .012
72 Plymouth Roadrunner 11.08@123.25
Re: issues with fresh 440 [Re: Roughbird72] #2722573
12/08/19 04:12 PM
12/08/19 04:12 PM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
#6 exhaust lifter face is slightly concave but no marks on it.
Re: issues with fresh 440 [Re: stinger] #2722580
12/08/19 04:48 PM
12/08/19 04:48 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
So that lifter is trash, at least... hopefully it was just "soft" and didn't damage the mating lobe, but I'd be worried about the cam too. scope
Re: issues with fresh 440 [Re: stinger] #2722582
12/08/19 05:00 PM
12/08/19 05:00 PM
So. Burlington, Vt.
So. Burlington, Vt.
Let’s see a pic....... but....... it’s done.
What starts out as slightly concave becomes:
Re: issues with fresh 440 [Re: fast68plymouth] #2722584
12/08/19 05:06 PM
12/08/19 05:06 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
party over. clean the mess up and try a different cam/lifters.
Re: issues with fresh 440 [Re: lewtot184] #2722596
12/08/19 05:53 PM
12/08/19 05:53 PM
So. Burlington, Vt.
So. Burlington, Vt.
I’ll add that if the cam being used is a Purple Plus 509 cam, those use .904 lifter diameter lobes.
Sometimes the factory lifter bore positioning is such that a .904 specific lobe has the profile running off the edge of the lifter.
“If it were me”, I would use a cam that had a lobe profile that didn’t require .904 lifters.
Assuming the PP509 was a good match for the overall combo, something like a 21-314-4 would provide for a similar powerband and “character”, but doesn’t require the .904 lifter.
You’d possibly be giving up a few ponies.
An Isky 292 Mega-cam would be another option, along with the Howard’s Big Daddy Rattler.
All of those recommendations assume you’re running headers.
Page 1 of 3 1 2 3
