Re: Carter Mechanical Fuel Pump
[Re: roy282]
#2722385
12/07/19 07:24 PM
12/07/19 07:24 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Aftermarket. 6902 or M6902 was the version for LA engines. Called "Super Street" 6903 is prob the same line for big blocks. Advertised pressure limit on the Super Street Carters was 6 psi so no additional regulator needed.
[Re: roy282]
#2722864
12/10/19 01:26 AM
12/10/19 01:26 AM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
I have a Super Street Small block unit that I will be using on my 410 stroker.
These were low pressure but higher volume than the OEM. Hussle Stuff sold the 'Kit' for it with the diaphragm and two stages of springs for pressure. I have that kit somewhere....
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Dave_J]
#2722877
12/10/19 07:34 AM
12/10/19 07:34 AM
Posts: 2,179 Walton, Indiana
TimS
Walton, Indiana
Back in the 90's/early 2000's we built these at the Logansport, IN Carter/ Federal Mogul plant.
Date code:
6903= Part # (as stated) 0= 2000 or 2010 G19= July 19th C= 3rd shift.
Just some more data.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor 1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic 1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow 1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top 2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue 2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black 2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
[Re: dragon slayer]
#2723388
12/12/19 07:33 AM
12/12/19 07:33 AM
TimS
Walton, Indiana
Tim, Thank you for that information very helpful. Do you know when the 6903 and 4862 first showed up year wise? Not sure off the top of my head but I can probably find that out. I'll check it out.
