Page 2 of 3 1 2 3
Re: Assassin bars. [Re: OhioMopar] #2548265
09/10/18 09:18 AM
09/10/18 09:18 AM
Indianapolis In. usa
Quickrunner Offline
Quickrunner  Offline
Originally Posted By OhioMopar
Originally Posted By Quickrunner
I am using the Smith assassin bars in my build. I went with Calvert for the split mono springs.
Thank you for the reply. Have you had your setup out yet?
Car is still under construction.
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Assassin bars. [Re: OhioMopar] #2548305
09/10/18 11:34 AM
09/10/18 11:34 AM
Cleburne,Texas
scrapmetal Offline
scrapmetal  Offline
Cleburne,Texas
I've got sum still in the box.I need to install them!One of my friends got them of one off their employees and gave them to me.Smith isn't that far from me!
Re: Assassin bars. [Re: OhioMopar] #2548335
09/10/18 12:28 PM
09/10/18 12:28 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
You can't go wrong with either. I have Cal tracs on my car and no complaints. I have thought about switching to the Smith bars for a little more adjustability but I've been 1.24 short time and not sure how much more I could do with a DOT approved 26" radial tire
Re: Assassin bars. [Re: OhioMopar] #2548409
09/10/18 03:12 PM
09/10/18 03:12 PM
LEBANON;PA
daron Offline
daron  Offline
LEBANON;PA
Smith bars work great and i had no issue with customer service
Re: Assassin bars. [Re: OhioMopar] #2721902
12/06/19 12:02 AM
12/06/19 12:02 AM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Does anyone have a picture of how the shocks mount on the Assassin spring plates?
Re: Assassin bars. [Re: 65Fury440] #2721937
12/06/19 08:39 AM
12/06/19 08:39 AM
E
earlymopar Offline
earlymopar  Offline
E
It may be different based on the application. I cut the shock plates down on my 65 Dodge pickup because the stock shock mount plate wouldn't fit with the Assassin rear end plate. I don't have a picture but I ended up with a shock mount plate that only uses 2 holes so it fits on one side of the Assassin plate.
- EM
Re: Assassin bars. [Re: earlymopar] #2722376
12/07/19 06:45 PM
12/07/19 06:45 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
I have heard of high HP cars bending springs at the cross bolt with cal tracs. That's one of the reasons I went with assassin bars plus theres more adjustability. They are very nice! I also went with smiths spring perches for them. Along with calvert split monos and sliders.
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Assassin bars. [Re: HOTMOPR] #2722419
12/07/19 10:42 PM
12/07/19 10:42 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
28 10.5 tire . Cal tracks for the win
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Assassin bars. [Re: OhioMopar] #2722515
12/08/19 12:25 PM
12/08/19 12:25 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
All the additional holes of the Assassin bars are only of benefit if you have a solid baseline from which to tune, as well as the time to test the various configurations. If not, I can see people getting lost among all the possibilities. There's something to be said for keeping the options to a usable minimum.
Re: Assassin bars. [Re: BradH] #2722520
12/08/19 12:45 PM
12/08/19 12:45 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
.. Agreed ..it's like buying a flashy fishing lure..99% of users More adjustment is not needed they have issues in other areas that need to be addressed... A lot of times more adjustability creates more variables and issues from what I have seen
Re: Assassin bars. [Re: WHITEDART] #2722524
12/08/19 12:51 PM
12/08/19 12:51 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I had guys tell me they couldn't get Cal-Tracs to work on a Mopar before I put them on mine. LOL. realcrazy
'63 Dodge 330
11.19 @ 121 mph
Re: Assassin bars. [Re: WHITEDART] #2722547
12/08/19 01:36 PM
12/08/19 01:36 PM
Washington
madscientist Offline
Washington
I'm a bit surprised you haven't bent a spring yet as quick as you are in 60 feet.
Re: Assassin bars. [Re: madscientist] #2722550
12/08/19 01:46 PM
12/08/19 01:46 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
There are holes for front or rear mount shocks. I thought they came with the studs but I can't find them so I can't confirm... Sorry it sideways..
Re: Assassin bars. [Re: HOTMOPR] #2722585
12/08/19 05:07 PM
12/08/19 05:07 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Thanks for looking, Calvert sells a set, I'll order them up.
Re: Assassin bars. [Re: madscientist] #2722594
12/08/19 05:50 PM
12/08/19 05:50 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
. Call Calvert tell them what the application and hp level is and they will set you up with the Spring that . Will be trouble free.
Re: Assassin bars. [Re: WHITEDART] #2722612
12/08/19 06:45 PM
12/08/19 06:45 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Its a known fact that much over 800 hp cal tracs bend split monos eventually. If youre at or above that hp level go with assassin bars.
Re: Assassin bars. [Re: HOTMOPR] #2722645
12/08/19 09:06 PM
12/08/19 09:06 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Ran CalTracs leaf springs and bars for years. Tried both holes and settled on the lower hole.
Best 60 ft@ 3700 lbs (race weight) 1.38. Best et was 9.88@ 135
Used stock shock plates and reinforced the spring perches.
I would recommend them.
Re: Assassin bars. [Re: HOTMOPR] #2722682
12/09/19 12:52 AM
12/09/19 12:52 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
...more Fake news...
Re: Assassin bars. [Re: WHITEDART] #2722689
12/09/19 03:48 AM
12/09/19 03:48 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Pretty good thread over on yellow bullet. But believe whatever you want bro..
Re: Assassin bars. [Re: HOTMOPR] #2722706
12/09/19 09:32 AM
12/09/19 09:32 AM
E
earlymopar Offline
earlymopar  Offline
E
There are (a lot) of other variables in addition to HP that would contribute to that.
- EM
Page 2 of 3 1 2 3
