ASSASSIN BAR QUESTION #2722096
12/06/19 06:51 PM
12/06/19 06:51 PM
Spring Hill Fl
65Fury440 Offline OP
Spring Hill Fl
Do Smith Racecraft assassin bars use stock rear shock length and location?
Re: ASSASSIN BAR QUESTION [Re: 65Fury440] #2722260
12/07/19 11:24 AM
12/07/19 11:24 AM
K
Kiddart Offline
Kiddart  Offline
K
from what I have read and been told yes they do direct bolt on
Thank you
Kiddart
Re: ASSASSIN BAR QUESTION [Re: Kiddart] #2722371
12/07/19 06:36 PM
12/07/19 06:36 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Yes they do. I am 90% sure they come with the shock studs too. I can check tomorrow.
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: ASSASSIN BAR QUESTION [Re: HOTMOPR] #2722506
12/08/19 11:59 AM
12/08/19 11:59 AM
Spring Hill Fl
Spring Hill Fl
I called Smith, and the guy I spoke to , while really nice, was honest in saying he really didn't know if they came with studs or not.
He also mentioned a Mopar application used Camaro shocks.
I searched for pics and really only found one showing a A body where the shocks looked vertical.
I will call back and press harder. Thanks for the replies.
Re: ASSASSIN BAR QUESTION [Re: 65Fury440] #2722707
12/09/19 09:35 AM
12/09/19 09:35 AM
E
earlymopar Offline
earlymopar  Offline
E
They do not come with studs or at least mine did not. But, it may be based on the car or pickup model the bars and mounting plates are for.
- EM
