New Product - Low mount 60A kits #2722072
12/06/19 04:10 PM
12/06/19 04:10 PM
AndyF Offline OP
AndyF  Offline OP
I have low mount kits for the Denso 60A alternator. There is a different kit for B and RB engines so be sure to order the correct one. The Denso 60A alternator is getting a little hard to find these days. I've seen some for sale on Amazon and 440Source has some but Summit has been out of stock for a while. The low mount kit is designed for engines which do not have a mechanical fuel pump. So either an engine that has been converted to EFI, or has an electric pump with no mechanical pump. I prefer the low mount design since it provides more room up top. The TDC mark is still visible since the alternator is under the sight line.
http://arengineering.com/products/low-mount-60a-kit-bb/
Re: New Product - Low mount 60A kits [Re: AndyF] #2722148
12/06/19 09:59 PM
12/06/19 09:59 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Nice solution. up
OT, why the phenolic(?) spacer on the EFI throttle body?
Re: New Product - Low mount 60A kits [Re: AndyF] #2722164
12/06/19 10:46 PM
12/06/19 10:46 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
got one for a hemi ?
Re: New Product - Low mount 60A kits [Re: calrobb2000] #2722177
12/06/19 11:24 PM
12/06/19 11:24 PM
AndyF Offline OP
AndyF  Offline OP
Depends on how the Hemi is dressed. If you're using big block pulleys and damper then the RB version should work. I don't intend to make a Hemi version. I used to make Hemi alternator brackets but they don't sell well enough to continue to invest in them.
Re: New Product - Low mount 60A kits [Re: jcc] #2722255
12/07/19 11:17 AM
12/07/19 11:17 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Originally Posted by jcc
Nice solution. up
EFI is still subject to fuel heating.
68 Barracuda Formula S 340
Re: New Product - Low mount 60A kits [Re: jcc] #2722272
12/07/19 12:14 PM
12/07/19 12:14 PM
AndyF Offline OP
AndyF  Offline OP
Nice solution. up
I was probably mocking up parts when the pictures of the alternator bracket were taken.
Re: New Product - Low mount 60A kits [Re: AndyF] #2722278
12/07/19 12:37 PM
12/07/19 12:37 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Do you do custom work?
Re: New Product - Low mount 60A kits [Re: AndyF] #2722418
12/07/19 10:39 PM
12/07/19 10:39 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
Andy, have you ever considered making engine mount kits similar to the Schumacher kits? Seems it's getting harder to get pieces from them lately, especially the big block headers and some of the big block mount kits.
Re: New Product - Low mount 60A kits [Re: Sniper] #2722432
12/07/19 11:44 PM
12/07/19 11:44 PM
AndyF Offline OP
AndyF  Offline OP
I do custom work all day long, but only for myself.
Re: New Product - Low mount 60A kits [Re: elmor353] #2722433
12/07/19 11:45 PM
12/07/19 11:45 PM
AndyF Offline OP
AndyF  Offline OP
No, I don't want to get into that. I've build engine mounts for myself but I don't want to compete with Michael.
