New bronze distributor gear tight
#2722099
12/06/19 06:54 PM
12/06/19 06:54 PM
Posts: 4,179 California
mickm
California
I'm putting a new gear in, and it is tighter than the old one, and I don't remember the old one being this tight when new.
When twisting it down to fall in place, it take a little effort. I'm not forcing it, but it does take some twisting effort, and when removing it it definitely takes more effort than the old one.
This one is a mopar piece, I know the old one was not.
I measured the OD of both units, and they are exactly the same, so it has to be the gears cut somewhat differently.
Is this an issue?
Re: New bronze distributor gear tight
[Re: mickm]
#2722131
12/06/19 09:10 PM
12/06/19 09:10 PM
Posts: 43,129 Bend,OR USA
Cab_Burge
Measure the oil pump shaft diameter and look closely at the oil pump drive bushing to see if may be causing your problem with the new Milidon oil pump drive with the new bronze gear I would loosen the oil pump and lower it or remove it to see if the new shaft fits better that way if you can't determine what is causing the iseue
[Re: Cab_Burge]
#2722143
12/06/19 09:44 PM
12/06/19 09:44 PM
mickm
California
Measure the oil pump shaft diameter and look closely at the oil pump drive bushing to see if may be causing your problem with the new Milidon oil pump drive with the new bronze I would loosen the oil pump and lower it or remove it to see if the new shaft fits better that way if you can't determine what is causing the iseue Ah, you would think I would learn over time, having done enough of this, but no... In my description I should have pointed out that it is only when the gear is engaging with the teeth on the camshaft that it is tight. That being said, it doesn't mean it isn't the pump. Although in that case it would be the shaft of the gear drive, as the old one did not have this issue. I'll try that out and let you know.
[Re: mickm]
#2722308
12/07/19 02:16 PM
12/07/19 02:16 PM
Posts: 982 western pennsylvania
b1dartsport
Is this an issue? I had the same issue mocking up a new engine. I had to remove the oil pump to get it back out. Sometimes these new R3 blocks need some clearancing in that area but that was'nt the problem. This motor has a brand new roller cam also so i'm not sure if its the pump gear or the cam gear. I used this shaft before with no problems and I replaced the gear..
[Re: b1dartsport]
#2722317
12/07/19 02:57 PM
12/07/19 02:57 PM
Posts: 2,637 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Could be the bushing is tight. (I know you said the other shaft spun ok.) Sometimes when I put one in without using the proper tool to burnish the bore on the way out they are tight.
2011 Drag Pak Challenger
[Re: John_Kunkel]
#2722329
12/07/19 03:51 PM
12/07/19 03:51 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I had to lightly file the hex end on one of the drives I've had over the years. I also had to put one in the drill to clean up the shaft with with fine sandpaper.
[Re: b1dartsport]
#2722422
12/07/19 10:58 PM
12/07/19 10:58 PM
b1dartsport
Is this an issue? I had the same issue mocking up a new engine. I had to remove the oil pump to get it back out. Sometimes these new R3 blocks need some clearancing in that area but that was'nt the problem. This motor has a brand new roller cam also so i'm not sure if its the pump gear or the cam gear. I used this shaft before with no problems and I replaced the gear.. I have the burnishing tool and I used it as always on this engine. I am beginning to think that the op has a point that these new gears are being cut a little different. I never had this problem before.
