Page 2 of 4 1 2 3 4
Re: 511 Indy tunnel ram which carbs [Re: Hot 340] #2721791
12/05/19 06:41 PM
12/05/19 06:41 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
I run 2 750's on my 505ci. The car went faster with the tunnel ram then the single 4. I drive it on the street and it runs well.
Re: 511 Indy tunnel ram which carbs [Re: AndyF] #2721806
12/05/19 07:07 PM
12/05/19 07:07 PM
PA
Harry's Taxi 2 Offline
PA
Originally Posted by AndyF
Originally Posted by mopar dave
Andy, I'm leaning toward Indy t ram with ultra xp 650's for my combo. How much power do you think the eddy 500's can make on my combo?
XP 650 carbs will cost a lot more than a pair of Edelbrock carbs. For your engine and your use the Edelbrocks will work fine and save you a ton of money. Or, if you're ready to go EFI get a dual Sniper setup with a Hyperspark distributor. Then you'll have full digital control of your fuel curve and ignition. You'll also have wide band feedback so you'll know what your air fuel ratio is and you'll be able to run data logs on the street or track. Something like that would answer a lot of questions that you have.
This makes no sense, on the one hand the advice is to save a buck by going with edelbrocks and then the next is the advice to spend a small fortune for a setup that, at best will equal a pair of well tuned carbs. (with the exception of cold start drivability)
As a reply to the OP's question, a pair of properly tuned 650 Holley's will run and drive quite well....although I'd go with the 750 Holley's as I've run both as well as 625-750 carter/edelbrocks and drivability is pretty much the same, but the 750's have equal throttle body sizes for a little more equal distribution.
Also, the annular boosters are available in the 750's to which I recently did a little back to back testing between them and downlegs, with the annulars having a "slight" et advantage over downlegs. I suspect with your car being a little heavier than mine, annulars would probably be the better choice.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: 511 Indy tunnel ram which carbs [Re: Harry's Taxi 2] #2721812
12/05/19 07:31 PM
12/05/19 07:31 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
This is where I figured he could save 1k$ by running his current 1050 single carb and get what 2 carbs he wanted later.
Re: 511 Indy tunnel ram which carbs [Re: Harry's Taxi 2] #2721815
12/05/19 07:33 PM
12/05/19 07:33 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Yeah, alot of people run 750's on there t ram. I think twin 750 Holley carbs is the way to go. They can grow with your program and resale is probably better than the 650 as well. Good advise from hardcoreB. I think I have alot to learn here as this will be my first t ram.
Re: 511 Indy tunnel ram which carbs [Re: Harry's Taxi 2] #2721819
12/05/19 07:55 PM
12/05/19 07:55 PM
AndyF Offline
AndyF  Offline
It makes sense if you understand the benefits of EFI. Not only do you get full computer control of the fuel curve and the ignition timing but you also get data logging. If you have paid any attention to Dave's posts over the past year he could use a lot of help in all three areas. If he had a properly functioning EFI system on his car (which might not be a realistic goal) then he would be able to resolve a lot of his questions. It isn't really about maximum power output for Dave since he is way off that curve anyway.
Re: 511 Indy tunnel ram which carbs [Re: mopar dave] #2721824
12/05/19 08:07 PM
12/05/19 08:07 PM
PA
PA
When you get to the point of needing an initial calibration starting point, I'd be happy to let you know what my carbs ended up at for a start. I will add, that a fair amount of initial timing helps quite a lot as far as off-idle drivability. I have 28*initial 36* total.......starts fine hot 493 with 13.3-1 and 273* @ .050
Re: 511 Indy tunnel ram which carbs [Re: AndyF] #2721828
12/05/19 08:23 PM
12/05/19 08:23 PM
PA
PA
Yes, I understand the benefits of EFI......since the middle to late 80's and in recent years it's just become the latest aftermarket shiny sale item.......does nothing better than a tuned carb, a little distributor work and a $600 +/- O2 recorder (again, with the exception of cold weather drivability and that can even be worked out with a little choke creativity)
It does make a car a little lighter.....in the drivers wallet area.
Re: 511 Indy tunnel ram which carbs [Re: Harry's Taxi 2] #2721855
12/05/19 09:37 PM
12/05/19 09:37 PM
AndyF Offline
AndyF  Offline
You're missing the whole point of the thread (and all of the other threads started by the OP)
Re: 511 Indy tunnel ram which carbs [Re: Harry's Taxi 2] #2721858
12/05/19 09:41 PM
12/05/19 09:41 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Have Dom do up a set of 750's. You won't beat the performance. You can't beat the looks on his stuff.
[image][/image]
Re: 511 Indy tunnel ram which carbs [Re: sgcuda] #2721896
12/05/19 11:21 PM
12/05/19 11:21 PM
Mt Morris Michigan
Mt Morris Michigan
Doms stuff is the best of the best for sure.
Re: 511 Indy tunnel ram which carbs [Re: Harry's Taxi 2] #2721897
12/05/19 11:29 PM
12/05/19 11:29 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks for the offer. Not sure what direction I will go yet, but if I buy the xp's and recalibrate myself I will need that kind of info.
Re: 511 Indy tunnel ram which carbs [Re: mopar dave] #2721914
12/06/19 01:16 AM
12/06/19 01:16 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
I run 2 Eddy 800's and used to run the 750's. The 800's made more HP on the dyno and also were 1/10 quicker on the track with a back to back test. I do have a couple of sets of the 750's if interested.
Re: 511 Indy tunnel ram which carbs [Re: max_maniac] #2722002
12/06/19 12:03 PM
12/06/19 12:03 PM
Mt Morris Michigan
Mt Morris Michigan
Thatnks for the offer, but i'm staying with a holley 4150 carb. I'm familiar with the holleys and like their performance as well.
Re: 511 Indy tunnel ram which carbs [Re: sgcuda] #2722009
12/06/19 12:16 PM
12/06/19 12:16 PM
Mt Morris Michigan
Mt Morris Michigan
I spoke with Dom last night and I really would like to have his billet carbs poking up thru my hood. We determined 750's would be best for my combo. With Dom not only are you getting a premium product, but you also get premium service after the sale. With all that in mind I still have the urge to pull the trigger on a pair of ultra xp's and recalibrate myself. Also their is word out there that the Holley ultra xp line is not so good. Decisions decisions. I'm going to ponder this a few more days, but Holley 750's with downlegs is what Dom has suggested. I can get the Indy tunnel ram any time and I was just told Dwayne is an Indy dealer as well.
Re: 511 Indy tunnel ram which carbs [Re: mopar dave] #2722012
12/06/19 12:28 PM
12/06/19 12:28 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... Also their is word out there that the Holley ultra xp line is not so good...
Like a lot of off-the-shelf carbs sold today, their calibration may be "less than optimal" for what they get put on.
This one doesn't suck as much as it used to, after a combination of work by AED and myself.
Re: 511 Indy tunnel ram which carbs [Re: BradH] #2722018
12/06/19 12:59 PM
12/06/19 12:59 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
for the money that's gonna be spent on new carbs and a tunnel ram, couldn't you send the intake manifold to Wilson to be ported?
Re: 511 Indy tunnel ram which carbs [Re: krautrock] #2722021
12/06/19 01:04 PM
12/06/19 01:04 PM
Mt Morris Michigan
Mt Morris Michigan
I could, but no longer interested. I will use it one more season and then it will go down the road as well as the Dominator.
Re: 511 Indy tunnel ram which carbs [Re: BradH] #2722025
12/06/19 01:09 PM
12/06/19 01:09 PM
Mt Morris Michigan
Mt Morris Michigan
If the calibration is the issue with the xp line, then that's not a big deal as I would be recalibrating the carbs for the t ram. I thought there may have been an issue with the venture design as well?
Re: 511 Indy tunnel ram which carbs [Re: mopar dave] #2722026
12/06/19 01:13 PM
12/06/19 01:13 PM
Washington
madscientist Offline
Washington
As Brad pointed out in the post after this one, the XP Holley's I have been into (3 total) and every one of them had a different calibration and they were all the same part number!!!!
The last one was about a month ago and I was pin gauging all the holes and the IFR were .059! On both the primary and secondary metering blocks. And the IAB's were normal. So I called Holley and got some guy on the line and told him that. I also told him the calibration differences between the three carbs. He had no answer for that. He also said the IFR for that carb should be .029!
The point is you'd be better off letting Dom get you sorted out, especially if you've never set up TR carbs because it's nowhere near the same.
If you are a guy who enjoys the process and you do want to do the carbs yourself (I have no problem with this because that's the best way to learn) long before I bought a Holley carb I'd buy the ProForm 750 and start with those. Much less money and just as good or better carb to start with.
Re: 511 Indy tunnel ram which carbs [Re: madscientist] #2722034
12/06/19 01:49 PM
12/06/19 01:49 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks for that piece of info. I have a good idea about whats needed, but I know there will be a big learning curve involved. I really like doing this stuff and not new at it. I do enjoy carb work, always have. I know if I buy carbs and do the calibrating myself, they will not be as good as Doms billet pieces. Carbs are very expensive and if ya want the best you have to step up to the pay window. That's my problem.
Page 2 of 4 1 2 3 4
