Page 1 of 4 1 2 3 4
511 Indy tunnel ram which carbs #2721545
12/05/19 12:48 AM
12/05/19 12:48 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
working on another induction option. 511 with 12.5:1 compression a 270@50 SFT and an Indy 400-I4-15 t ram. Street/strip deal, which carbs would give best all around performance, 650,660 or 750? I see most like the 750's and there are some that like the 660's. My thinking is to err on the small side with the 650's. It seems the Indy tunnel ram has a very large plenum and I thought maybe the smaller carbs would help crutch this on this combo. 5100 stall and car weights 3380#. Appreciate your opinion on this. Thanks
Re: 511 Indy tunnel ram which carbs [Re: mopar dave] #2721551
12/05/19 02:03 AM
12/05/19 02:03 AM
Washington
madscientist Offline
Washington
I would throw the 660's in the river. Or sell them to someone still living in 1975. The absolute smallest carbs I would run would have a 1.410ish Venturi and 1.750 throttle blades. There is no reason you can't call Dom and do a couple of 1050 Dominators and really kick [censored].
No vacuum secondary carb. Most guys err on the small side and don't buy a cam for the TR. If that cam wasn't ground specifically for the TR I'd sell it and get one that is. And a minimum of two 750's. A very, VERY smart guy who worked for a very cool company once told me to really get the correct carb on a TR you double what you'd be using on a single 4. And he told me that in 1982. It still stands today.
Re: 511 Indy tunnel ram which carbs [Re: mopar dave] #2721554
12/05/19 02:26 AM
12/05/19 02:26 AM
I like the early non HP Holley 1050 CFM Dominator list #9375 on both tunnel rams as well as on a good single plane BB Mopar intake, those carbs flat work well up,
Especially with M.W type heads, more air and fuel = more power boogie
Re: 511 Indy tunnel ram which carbs [Re: mopar dave] #2721575
12/05/19 07:33 AM
12/05/19 07:33 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
So, you're considering a t-ram, or you've bought one?
Re: 511 Indy tunnel ram which carbs [Re: HardcoreB] #2721591
12/05/19 08:59 AM
12/05/19 08:59 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
The INDY tunnel ram has a SMALL plenum. IIRC it was about 300cc
Re: 511 Indy tunnel ram which carbs [Re: BradH] #2721595
12/05/19 09:17 AM
12/05/19 09:17 AM
Mt Morris Michigan
Mt Morris Michigan
Just researching it at the moment Brad. The m1 tunnel ram seems to be the one to have, but can't find one. The Indy is available and will most likely be the one I buy. This is just something I have always wanted to do since I was in high school. Mostly for the old school look for the car show or two I hit, but I don't want to lose any performance. Gonna black everything out and would like to use the black and grey ultra xp carbs. Think that would look sweet sticking up thru the black hood. Working sh!t tons of hours now, so i'm gonna get started on buying parts for this project. Should be able to get started installing them this time next year. The 511 will run with 12.5:1 compression as the only change next year, so I need to see for myself what a compression bump can do for performance. I read somewhere else too that a T ram likes a cam 7-10* smaller than your best cam in a single carb/standard intake combo and thought since my cam will be on the small side with the 12.5:1 compression it might work out quite well. When I do get a roller it will be for a t ram application, but for now this cam stays. I just want to get the carbs right as its the only question I have right now for this combo. I will be talking to Dom about this as well. It has crossed my mind running twin 750 Dominators, but I haven't seen any combos with those carbs. I have seen some that ran a single 1050, installed a T ram with twin 1050's and didn't pick up anything. Then there are some that ran a single 1050 and installed a t ram with twin 750's and went faster. So, right now i'm a bit skeptical on twin 1050's especially on the street.
Re: 511 Indy tunnel ram which carbs [Re: HardcoreB] #2721604
12/05/19 09:58 AM
12/05/19 09:58 AM
Mt Morris Michigan
Mt Morris Michigan
Are you referring to the runner or the plenum? Pretty sure the plenum is more than 300cc. The 750's you have for sale, are they the ones in your avatar?
Re: 511 Indy tunnel ram which carbs [Re: mopar dave] #2721621
12/05/19 10:57 AM
12/05/19 10:57 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I believe the plenum on a single 4 should be 1.5x the volume of 1 cylinder so I wonder what a tr should be.Would the tr carbs be side mount or in line?
Re: 511 Indy tunnel ram which carbs [Re: Clanton] #2721627
12/05/19 11:13 AM
12/05/19 11:13 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
Can the M1 or Weiand TRs be ported to max wedge size as well?
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: 511 Indy tunnel ram which carbs [Re: Clanton] #2721636
12/05/19 11:41 AM
12/05/19 11:41 AM
Mt Morris Michigan
Mt Morris Michigan
Side mount only unless I run eddys.
Re: 511 Indy tunnel ram which carbs [Re: Den300] #2721668
12/05/19 01:12 PM
12/05/19 01:12 PM
PA
Harry's Taxi 2 Online content
Harry's Taxi 2  Online Content
PA
No for either one.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: 511 Indy tunnel ram which carbs [Re: mopar dave] #2721683
12/05/19 01:48 PM
12/05/19 01:48 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I also have a low deck m1 t/r.
Re: 511 Indy tunnel ram which carbs [Re: HardcoreB] #2721693
12/05/19 02:28 PM
12/05/19 02:28 PM
Mt Morris Michigan
Mt Morris Michigan
I like the idea on the annular boosters.
Re: 511 Indy tunnel ram which carbs [Re: mopar dave] #2721698
12/05/19 02:46 PM
12/05/19 02:46 PM
AndyF Offline
AndyF  Offline
Is this for your car? If so, I'd recommend a pair of small Edelbrock carbs. If you brought the engine to me I'd run it with a pair of 500 cfm Edelbrocks on the dyno and go from there. That setup can easily handle 800 hp and from what I recall, you're not making anything close to 800 hp right now.
Re: 511 Indy tunnel ram which carbs [Re: HardcoreB] #2721701
12/05/19 02:49 PM
12/05/19 02:49 PM
Mt Morris Michigan
Mt Morris Michigan
HardcoreB, your PM's are full. Shoot me a price on those 2 items. I may know someone interested.
Re: 511 Indy tunnel ram which carbs [Re: AndyF] #2721704
12/05/19 02:52 PM
12/05/19 02:52 PM
Mt Morris Michigan
Mt Morris Michigan
Andy, I'm leaning toward Indy t ram with ultra xp 650's for my combo. How much power do you think the eddy 500's can make on my combo?
Re: 511 Indy tunnel ram which carbs [Re: mopar dave] #2721719
12/05/19 03:16 PM
12/05/19 03:16 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Just call me and we'll get you hooked up w/proven carbs like the several t-rams I've done w/great success..........I would not run Dommy's on that combo personally unless you want the "look" because they would have to be be sized down to run well imo.......
Re: 511 Indy tunnel ram which carbs [Re: Thumperdart] #2721726
12/05/19 03:32 PM
12/05/19 03:32 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Could he run a single carb?
Re: 511 Indy tunnel ram which carbs [Re: mopar dave] #2721756
12/05/19 05:01 PM
12/05/19 05:01 PM
AndyF Offline
AndyF  Offline
XP 650 carbs will cost a lot more than a pair of Edelbrock carbs. For your engine and your use the Edelbrocks will work fine and save you a ton of money. Or, if you're ready to go EFI get a dual Sniper setup with a Hyperspark distributor. Then you'll have full digital control of your fuel curve and ignition. You'll also have wide band feedback so you'll know what your air fuel ratio is and you'll be able to run data logs on the street or track. Something like that would answer a lot of questions that you have.
Re: 511 Indy tunnel ram which carbs [Re: madscientist] #2721783
12/05/19 06:19 PM
12/05/19 06:19 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Good post. Glad somebody understands how a tunnel ram works.
Page 1 of 4 1 2 3 4
