Page 7 of 10 1 2 5 6 7 8 9 10
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2701852
09/28/19 09:36 PM
09/28/19 09:36 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
[[Linked Image]
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2704055
10/05/19 10:17 AM
10/05/19 10:17 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
I wanted to reinforce the inner fenders so here's whats Matt came up with. The bottom plate ties into the plate on the bottom side of the shock tower.
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2706812
10/14/19 07:44 PM
10/14/19 07:44 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Lower radiator support needed reinforced and I didn't like any of the aftermarket options...
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2707892
10/17/19 11:59 PM
10/17/19 11:59 PM
Superfreak
Superfreak
Nice work
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: ] #2713344
11/06/19 01:14 PM
11/06/19 01:14 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Originally Posted by Superfreak
Nice work
Thanks!
I want safer updated seat belts but I'm not wanting any racing seatbelts. I don't want to be tied down in one place for everyday driving and yet I don't want to sacrifice safety...so I knew I wanted an inertial reel...so the seatbelts from a 2010 Challenger were chosen. In the 2010 challenger, they fit in a pocket in the pillar. The reel is mounted on a bracket that hangs by two hooks and is bolted at the bottom. The reel...
Next, Matt made a box for the reel bracket to hang on/mount to...
Hanging in place...
It's hard to show in the picture, but the belt fits flush with the inner sheetmetal panel. The factory door panel will fit right over it and will just need a slot for the belt to pass through. The final result will be a safe and comfortable belt system that uses everything from a late model challenger.
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2715561
11/13/19 10:31 PM
11/13/19 10:31 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The saga continues...after 9 months, the right humerus bones hadn't grown together very well. Monday, I had a bone graft surgery in which bone was taken from my right hip, ground up, mixed with some type of adhesive, packed in the bone joint all the way around, and then the bone joint was actually taped up. I was warned that the hip would hurt more then the arm, but I had no idea!! It feels like my stomach muscles were rearranged to get to the hip. If I cough or use my stomach/core muscles at all (and they are used all the time), the pain is brutal!!
I'm not sure when I'll be back out in the shop again since the arm needs about three months to fuse. Its a bit of a bummer, but at least I got the 68 roadrunner cleaned up and mounted on the rotisserie last weekend. Its scheduled to get media blasted and sealed in epoxy the first week in December.
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2717839
11/20/19 01:08 PM
11/20/19 01:08 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
A few odds and ends pics of the car getting cleaned up on the rotisserie...
Being upside down made it a lot easier to finish welding in the hard to get to areas
While I had it on each side, I used the needle scaler to knock the undercoating off the inside of the left quarter panel. I also spot checked the floor to find any little areas I may have missed.
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2717841
11/20/19 01:15 PM
11/20/19 01:15 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
I also took the opportunity to clean up the roof skin. I was really surprised that there wasn't ANY scale on the roof! I was mainly removing a yellow glue that was all over the skin. The roof structure wasn't scaly or rusty at all. It was still dusted red from the factory. It seems bizarre that this car did so well sitting out in a field for 20+ years...I can only guess that it aired out quickly without a windshield, rear window, or carpet in it.
Re: 1968 Roadrunner Post w/ 6.1L Hemi, 6 speed, and IRS [Re: 70B5Cuda] #2721385
12/04/19 03:45 PM
12/04/19 03:45 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Great work!
Best of luck with your health and the remainder of the build.
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2721453
12/04/19 07:38 PM
12/04/19 07:38 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
It looks like there should not be any flex in the car ! Very nice work. It's cleaning up nice. Should be fun to drive !
Praying for your improved health.
Mark
http://marsh-racing.com/Mark%20Mahorney-Allstate.htm
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: Hemi Allstate] #2721475
12/04/19 09:06 PM
12/04/19 09:06 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Thanks guys! I appreciate it!
The roadrunner went to the media blaster Monday, where aluminum oxide was used to clean it up inside and outside. It's fun to see it in bare metal and all in one color, but it's always disappointing to see the little spots that seem to come out of nowhere...
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2728532
12/31/19 12:58 PM
12/31/19 12:58 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The aluminum oxide brought a few things to light...the most disappointing was the drivers floor board. It looked really solid until blasted...so a partial patch went in...
[color:"silver"] - - - Updated - - - [/color]
Then it went in primer...
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2730510
01/06/20 12:16 PM
01/06/20 12:16 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Looking good!
'63 Dodge 330
11.19 @ 121 mph
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: GY3] #2731243
01/08/20 08:43 PM
01/08/20 08:43 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Originally Posted by GY3
Looking good!
Thanks Mark!
While it is on the rotisserie, it's time to spray some color. Original paint code was PP1 red but I went with R6 red, which was the color of my wrecked 69 survivor Charger. I LOVE the color stage!!!
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2731351
01/09/20 09:46 AM
01/09/20 09:46 AM
OH
Red383 Offline
Red383  Offline
OH
That looks great, nice work.
Aaron
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: Red383] #2731355
01/09/20 10:19 AM
01/09/20 10:19 AM
Chicago
rocksmopar Offline
rocksmopar  Offline
Chicago
Looks like you'll have it rolling by summer!
Looking for affordable Cuda parts
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: rocksmopar] #2736344
01/24/20 11:31 PM
01/24/20 11:31 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
That would be nice but I don't think I can move that fast!
Several lead joints were fractured, cracked, or missing so I had the pillar to cowl joints and the quarter panel to rocker joints re-leaded. The guy who did it did a really nice job
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2743382
02/15/20 11:03 PM
02/15/20 11:03 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The Roadrunner came off the rotisserie for some panel alignment. The hood, fenders, and doors were all pinned for easy removal and reinstallment.
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2748003
03/01/20 01:03 PM
03/01/20 01:03 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed [Re: 70B5Cuda] #2756754
03/28/20 09:08 AM
03/28/20 09:08 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
initial blocking is done and now its in slick sand.
