Page 32 of 48 1 2 30 31 32 33 34 47 48
Re: Modern Bullitt build [Re: Keepat] #2690601
08/23/19 11:25 AM
08/23/19 11:25 AM
Superfreak
Superfreak
As usual your work is very impressive.
Which spray gun did you use again for painting the car?
Robert
Re: Modern Bullitt build [Re: ] #2698546
09/17/19 07:00 PM
09/17/19 07:00 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Prepping for the headliner install this weekend
Pat
[Linked Image]fun things in fallout 3
Re: Modern Bullitt build [Re: ] #2698556
09/17/19 07:22 PM
09/17/19 07:22 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Robert
Robert, Iā€™m sorry I missed your question! I used a Sata jet 4000 B
Pat
Re: Modern Bullitt build [Re: Keepat] #2699416
09/21/19 12:52 AM
09/21/19 12:52 AM
Superfreak
Superfreak
Thanks Pat.
Re: Modern Bullitt build [Re: ] #2699868
09/22/19 01:56 PM
09/22/19 01:56 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I used Matt black vinyl to cover the silver insulation (recommended by others) then started to install the new headliner. This is the fourth car I install the headliner on, and it seems to be getting a little easier ;-)
[Linked Image]make image url online
Re: Modern Bullitt build [Re: Keepat] #2700024
09/23/19 05:53 AM
09/23/19 05:53 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Pat - that headliner looks very nice!
I like the insulation and black vinyl cover over as well.
Re: Modern Bullitt build [Re: larry4406] #2701148
09/26/19 02:15 PM
09/26/19 02:15 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
Excellent work as usual, though I think you are giving me a false sense of security that I can do mine, lol.
Also like the black Vinyl idea.
Re: Modern Bullitt build [Re: CDN72SE] #2715947
11/14/19 10:16 PM
11/14/19 10:16 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Tail panel is now matte black and stated installing the fuel, brake, AC, and hydro-boost lines.
Re: Modern Bullitt build [Re: Keepat] #2716106
11/15/19 02:05 PM
11/15/19 02:05 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Impressive work ! Very nice! up
Mark
http://marsh-racing.com/Mark%20Mahorney-Allstate.htm
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Modern Bullitt build [Re: ] #2716838
11/17/19 07:26 PM
11/17/19 07:26 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Robert
Thank you!
Pat
Re: Modern Bullitt build [Re: Keepat] #2716839
11/17/19 07:27 PM
11/17/19 07:27 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Install the brake and clutch master cylinder and pedal assembly today.
Pat
Re: Modern Bullitt build [Re: Keepat] #2717934
11/20/19 09:30 PM
11/20/19 09:30 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Installed the quarter extensions and the shaved & shortened rear bumper.
Pat
[Linked Image]host pictures
Re: Modern Bullitt build [Re: Keepat] #2717958
11/20/19 11:25 PM
11/20/19 11:25 PM
Superfreak
Superfreak
By "shaved" do you mean the sides where it wraps around to the 1/4 panel?
Looks fabulous by the way.
Re: Modern Bullitt build [Re: ] #2718008
11/21/19 07:55 AM
11/21/19 07:55 AM
west palm beach, florida
modelmakerinc Offline
Pat, As everyone else has said extremely impressive work and work environment, the time you take to photograph and document the build is equally as impressive.
Its a real shame that Photobucket blurs out all the previous pictures flame.
Couple questions:
1) With all of those lines and respective parts did you do a prefit prior to paint and body work or are you fabricating and installing all as you go?
2) on the vinyl roof install, i understand the center panel install but when you move to the side panels, Do you have any help, someone holding it up on one end? getting that wide a panel over an arched roof section and not touch the sail panel is a magic trick.
Henry
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Modern Bullitt build [Re: ] #2718011
11/21/19 08:41 AM
11/21/19 08:41 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Shaved refers to the bolt holes that were removed, But I also cut the bumpers down by a total of 3/4ā€œ, 3/8ā€ on each side.
Thank you!
Pat
Re: Modern Bullitt build [Re: modelmakerinc] #2718012
11/21/19 08:44 AM
11/21/19 08:44 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted by modelmakerinc
Pat, As everyone else has said extremely impressive work and work environment, the time you take to photograph and document the build is equally as impressive. With all of those lines and respective parts did you do a prefit prior to paint and body work or are you fabricating and installing all as you go?
Henry
Everything has been fitted to the car with exception of exhaust. I made all of the brake, fuel and AC lines over three years ago. (wow has it been that long :-)
Thank you!
Pat
Re: Modern Bullitt build [Re: Keepat] #2718343
11/22/19 11:12 AM
11/22/19 11:12 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Starting to look like a 68 Charger!
Pat
Re: Modern Bullitt build [Re: Keepat] #2720327
11/29/19 08:12 PM
11/29/19 08:12 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Fuel tank along with supply and return fuel lines are install!
Re: Modern Bullitt build [Re: Keepat] #2720328
11/29/19 08:16 PM
11/29/19 08:16 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I also installed the rear. Shooting to put the engine transmission & front suspension in the car over the weekend.
Pat
Re: Modern Bullitt build [Re: Keepat] #2720495
11/30/19 06:41 PM
11/30/19 06:41 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Wow,nice work! This whole build is perfection!
