Is there a rear leaf spring part number chart available? #2719112
11/25/19 10:49 AM
11/25/19 10:49 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Does anyone have a chart with the highlighting the rear leaf spring part numbers for A, B and E-Bodies?
Re: Is there a rear leaf spring part number chart available? [Re: vinnyd76] #2719163
11/25/19 01:35 PM
11/25/19 01:35 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Specifically looking for A-Body 340 Leaf Spring part numbers for models years 69-72
Re: Is there a rear leaf spring part number chart available? [Re: vinnyd76] #2719196
11/25/19 02:57 PM
11/25/19 02:57 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
There's a chart in the Archives here.
On a few occasions, I've come across spring #s (mostly B-bodies or SS) that aren't on any chart.
Re: Is there a rear leaf spring part number chart available? [Re: vinnyd76] #2719340
11/25/19 11:02 PM
11/25/19 11:02 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
My '69 notchback Barracuda 340 came with 2835132 both sides.
Re: Is there a rear leaf spring part number chart available? [Re: kentj340] #2719497
11/26/19 03:45 PM
11/26/19 03:45 PM
oregon
greendart408 Offline
oregon
Both of my original 1969 340 swingers have 2835064s
Re: Is there a rear leaf spring part number chart available? [Re: greendart408] #2719625
11/27/19 01:05 AM
11/27/19 01:05 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
1971 A body 340 Duster is 081 081.
Re: Is there a rear leaf spring part number chart available? [Re: kentj340] #2719648
11/27/19 07:28 AM
11/27/19 07:28 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Thank you very much for the feedback!
I recently picked up a pair of 081 leaf springs. Trying to confirm years of usage for that spring. I also have a pair of 064 leaf springs from my 69 Dart, which aligns with another member’s feedback. Was the 081 leaf spring also used in 1970 on A-Bodies?
A couple of key differences between on my 064 and 081 springs are the number of leaf springs and the size of the front eye bushings. The 064 has 5-leafs and a 2” bushing and the 081 has 6-leaf springs and 1.5” bushing? Can anyone else confirm these features on theirs?
Re: Is there a rear leaf spring part number chart available? [Re: vinnyd76] #2719918
11/28/19 12:37 AM
11/28/19 12:37 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
If you still want factory part numbers for B and E bodies:
E-body 1970-71 Hemi, 440, 440-6, HD, 034/024.
E-body AAR TA, 048/048.
B-body 1967-71 Hemi, 440, 440-6, HD, 965/795, same as 964/794, 963/793.
These numbers do not appear in parts books.
Re: Is there a rear leaf spring part number chart available? [Re: kentj340] #2719945
11/28/19 05:44 AM
11/28/19 05:44 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Thank you for the feedback! Anyone have the rear leaf spring part number for a 1970 A-Body with a 340 (auto)?
Re: Is there a rear leaf spring part number chart available? [Re: vinnyd76] #2719953
11/28/19 08:02 AM
11/28/19 08:02 AM
FL
moparwizard Offline
moparwizard  Offline
FL
70' 340 auto 081 spring
Re: Is there a rear leaf spring part number chart available? [Re: vinnyd76] #2720731
12/01/19 06:43 PM
12/01/19 06:43 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
There's info but scattered. Bill Rolick started a thread to compile but don't know if he followed up since his original post.
The challenge is it seems that the stamped number has no relation to the part number.
It does relate to the number on the broad cast sheet.
See here: https://board.moparts.org/ubbthread...identification-for-what-application.html
Some springs also have date and other codes. shruggy
Is the stamped number a production part number, and that's why it doesn't show in the parts books?
Or is the stamped number jdifferent because it had a different purpose and is not the part number used for ordering?
Re: Is there a rear leaf spring part number chart available? [Re: Mattax] #2720836
12/02/19 09:36 AM
12/02/19 09:36 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Was there a 293 / 293 spring set?
Trying to help a guy.
Both springs are stamped
3722293.
36369. 020 4
On '68 H code Dart
Current owner says the car was drag raced so a good chance these are replacements but if so, from what?
