Page 3 of 3 1 2 3
Re: Will this stock stroke 440 make 700hp? [Re: 451Mopar] #2719417
11/26/19 11:05 AM
11/26/19 11:05 AM
an8sec70cuda Offline
Originally Posted by 451Mopar
With a 5,000 Stall converter who cares about low end grunt smile
I know what you're saying up, but I'd expect a 5,000 stall to be too tight for this motor. My old 446" used a 5k stall w/ smaller heads and a lot less cam.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Will this stock stroke 440 make 700hp? [Re: Jonny440] #2719426
11/26/19 11:43 AM
11/26/19 11:43 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Seems reasonable and my 470 junk loves my .680-.660 276-281 @ .050 ISKY solid roller both street and strip for many trouble free years in the 9's and a blast to drive.....
Re: Will this stock stroke 440 make 700hp? [Re: Jonny440] #2719438
11/26/19 12:18 PM
11/26/19 12:18 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
Am I crazy or is 7000rpm with a stock 440 block going to crack the mains?
Re: Will this stock stroke 440 make 700hp? [Re: MoonshineMattK] #2719441
11/26/19 12:25 PM
11/26/19 12:25 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
In over 20 years of running 8.60’s-10.40’s I cracked one block and that one was a 500 inch Stroker engine with 440source billet main caps. No concrete, no girdle. Now I did crack several 440 forged cranks and got to the point if I got 3 years out of them they went on my scrap pile
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Will this stock stroke 440 make 700hp? [Re: MoonshineMattK] #2719453
11/26/19 01:11 PM
11/26/19 01:11 PM
Probably not, especially with a good balanced rotating crank assembly and a decent tune.
Detonation is the major cause of cracking the main webbing in 440 blocks, not RPM twocents
Re: Will this stock stroke 440 make 700hp? [Re: an8sec70cuda] #2719486
11/26/19 02:58 PM
11/26/19 02:58 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I would have never bet that my 15-1 comp 572 would need a 6100 converter. 5700 was to tight. Unless you're talking Q16 there us no reason to run C16. I've had zero issues with Renegade 114.
Doug
Re: Will this stock stroke 440 make 700hp? [Re: dvw] #2719489
11/26/19 03:14 PM
11/26/19 03:14 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Question: Assuming two engines make the same peak HP, what's more stressful on a bottom end?
a) 7500 RPM with a 3.75 stroke (451)
b) 6500 RPM with a 4.25 stroke (511)
Not meant to be a quiz; I'm curious about what's more likely to put the hurt to a marginal block. shruggy
Re: Will this stock stroke 440 make 700hp? [Re: BradH] #2719509
11/26/19 04:26 PM
11/26/19 04:26 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Personally I think bob-weight will play a bigger hand than stroke - in the last 511 I built - we got the bob weight below 2200 grams using the 7.1 rod and a 4.25 crank in an stock RB block - I also believe in aluminum main caps. The first 511 stroker I built with stock rod journal and rod length had a bob-weight of almost 2500 grams - it beat the stock main caps to death even with studs.
If its a light weight assembly and well balanced and not running into detonation- 7500 RPM does not seem to make much difference
Re: Will this stock stroke 440 make 700hp? [Re: DoubleD] #2719513
11/26/19 04:43 PM
11/26/19 04:43 PM
BradH Offline
BradH  Offline
FWIW...
3.75 x 7500 = mean piston speed 4688 ft/min; max 7363 ft/min
4.25 x 6500 = mean piston speed 4604 ft/min; max 7232 ft/min
4.25 x 7000 = mean piston speed 4958 ft/min; max 7788 ft/min
https://www.racepagesdigital.com/pi...ctive-forces-at-work-inside-your-engine/
Re: Will this stock stroke 440 make 700hp? [Re: BradH] #2719515
11/26/19 05:04 PM
11/26/19 05:04 PM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
I guess this is probably a dumb question, but can you calculate the max piston speed without knowing the rod length?
Also I think what really matters is max accel/decel
Re: Will this stock stroke 440 make 700hp? [Re: GTX MATT] #2719607
11/27/19 12:10 AM
11/27/19 12:10 AM
Me thinks the rod length has nothing to with the piston speed, the stroke and RPM does though work shruggy
I've heard that the rod length makes a difference on the piston speed at when changing directions on the stroke at BTDC and again at TDC but I've never understood that thinking confused
I can understand the cylinder wall loading differences between a short rod and a long rod with the same stroke up
Re: Will this stock stroke 440 make 700hp? [Re: Cab_Burge] #2719662
11/27/19 09:33 AM
11/27/19 09:33 AM
BradH Offline
BradH  Offline
Rod length affects dwell time at TDC & BDC; not required as an input for mean & max piston speed calculators.
Page 3 of 3 1 2 3
