NP208 removal question please
#2719283
11/25/19 07:52 PM
11/25/19 07:52 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
My trusty 84 Dodge plow truck lost reverse at the end of last winter, along with high gear. Of course I put off pulling it until now because I HATE working on rusty rusty stuff and frankly remain a novice at 4WD stuff.
Getting close to pulling the transfer case 1st, but am not sure which end of the adapter housing between the 727 and transfer case I should unbolt in order to separate them. Does it even matter? The Haynes manual is of no help. Advice?
One other thing; recommendation on where to find a new bushing for the transfer case lever. The existing one is shot.
Thanks in advance.
Lead, follow or get the hell out of the way
Re: NP208 removal question please
[Re: geo.]
#2719481
11/26/19 02:38 PM
11/26/19 02:38 PM
Posts: 1,881 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
I did this a long time ago, I think i separated it at the transmission end. I hope someone who's done it recently will verify!
On my '76 with an NP203 i pulled the engine at the same time and left the transfer case chained up under the truck. Your NP208 isn't as heavy so you might not need to do this!
I did the same on my '77 when the trans needed redone.Easier to pull it out of the front as those 203 cases are HEAVY! Plus no crossmember to mess with. RT
