Re: Track Racing Mopars!
[Re: jcc]
#2722449
12/08/19 12:11 AM
12/08/19 12:11 AM
Posts: 17,929 Akron, Ohio
ProSport
Akron, Ohio
Some awesome photos in this thread, I love seeing the corner carving Mopars. I've always loved that yellow Hotchkis Challenger and I finally have a car very similar.
Track Racing Mopars Do not overtire
[Re: ProSport]
#2722745
12/09/19 12:29 PM
12/09/19 12:29 PM
Posts: 2,483 Answering the call of the wild
ThermoQuad
I am away from here most of the time so patience is required. It takes a while for me to type something to detail. Technical support is only good if you use it. This is technical support. Remember the cars i build are driven normally like as in transportation that your wife can drive and run many hot laps on the road course track. When i built the Charger [car#2] our goal was to run the magic number at the Glen [Thunder Road] of 2.5 minutes on the full course on street tires and still have the wife drive it. We did both. The owner & wife passed away at 52 recently so track tires on the track are out of the question. I am now the caretaker of the car - awaiting license plates - so if i am lucky i will bring it to Carlisle and i may even run it at the Glen in June. It has factory type cruise control for those 80 mph interstate runs. The car is a blast to drive fast and easy to drive slow. The thinking is always to put huge tires on the car to make it handle better but huge tires come with compromises. A 26 inch tall tire with 10 inches of tread fits perfectly and looks perfect. No compromises means there is no rubbing or hitting in full travel and high speed driving/turning situations. The bigger tires require the proper selection of HD suspension parts and car needs structural modifications to eliminate flex. In other words back up the grip. I am not convinced that staggered tire sizes is practical from a handling geometry viewpoint on these cars from years of laps and normal {?} driving. You have to back up the big tires with good hardware on a solid platform. Weld & box the k frame is mandatory as are adjustable shocks, boxed lower control arms, aftermarket upper control arms, firm feel 3 box etc. 16:1 steering is perfect for the road course, i see no requirement for fasting ratios etc as that will not make the car faster in the turns so the lap times get better. Bling. Don't forget the brakes. Regardless of size you need proper tire selection to get the car to rotate in a turn - like it's on string. W or Z rated selection so you can switch to track tires if you really want fly. I ran both types of tires. The close to stock look of 255-50-16 inch tires on a retro look 16 inch wheel tires is a nice and proper look. You don't want car people to know the car is really a wicked wanda. An old muscle car with five spoke mag wheels. Btw a sidewall is required for ride comfort. Go look on the tire rack for a w rated street tire and track tire and there are no 17 inch selections. Tires
Re: Track Racing Mopars Do not overtire
[Re: ThermoQuad]
#2722789
12/09/19 04:34 PM
12/09/19 04:34 PM
Posts: 23,816 Here
jcc
No soup for you!!!
No soup for you!!!
Here
I am away from here most of the time so patience is required. It takes a while for me to type something to detail. Technical support is only good if you use it. This is technical support. Remember the cars i build are driven normally like as in transportation that your wife can drive and run many hot laps on the road course track. When i built the Charger [car#2] our goal was to run the magic number at the Glen [Thunder Road] of 2.5 minutes on the full course on street tires and still have the wife drive it. We did both. The owner & wife passed away at 52 recently so track tires on the track are out of the question. I am now the caretaker of the car - awaiting license plates - so if i am lucky i will bring it to Carlisle and i may even run it at the Glen in June. It has factory type cruise control for those 80 mph interstate runs. The car is a blast to drive fast and easy to drive slow. The thinking is always to put huge tires on the car to make it handle better but huge tires come with compromises. A 26 inch tall tire with 10 inches of tread fits perfectly and looks perfect. No compromises means there is no rubbing or hitting in full travel and high speed driving/turning situations. The bigger tires require the proper selection of HD suspension parts and car needs structural modifications to eliminate flex. In other words back up the grip. I am not convinced that staggered tire sizes is practical from a handling geometry viewpoint on these cars from years of laps and normal {?} driving. You have to back up the big tires with good hardware on a solid platform. Weld & box the k frame is mandatory as are adjustable shocks, boxed lower control arms, aftermarket upper control arms, firm feel 3 box etc. 16:1 steering is perfect for the road course, i see no requirement for fasting ratios etc as that will not make the car faster in the turns so the lap times get better. Bling. Don't forget the brakes. Regardless of size you need proper tire selection to get the car to rotate in a turn - like it's on string. W or Z rated selection so you can switch to track tires if you really want fly. I ran both types of tires. The close to stock look of 255-50-16 inch tires on a retro look 16 inch wheel tires is a nice and proper look. You don't want car people to know the car is really a wicked wanda. An old muscle car with five spoke mag wheels. Btw a sidewall is required for ride comfort. Go look on the tire rack for a w rated street tire and track tire and there are no 17 inch selections. Well that is polite and reasoned reply with many valid agreeable points. However my viewpoint is different. I agree as one "over tires" ANY vehicle, other mods need to be taken to utilize the larger(?) tires full traction circle. That DOS NOT mean there is no benefit from over tiring a vehicle without mods. I have not I believe, anywhere suggested there is no downside in over tiring a car, in the realm of additional rotational mass, higher aero drag, aqua planing, cost, unbalancing due to poor size selection per axle, etc. However one can on their own decide if the benefits in "overtiring" is worth the cost, in areas of higher driving performance, decreased braking distance ,etc. My life experience in over 4 decades of "over tiring", and thru nearly all the sharing of others in that time, other then this thread, I have yet to review a solid case of how over tiring is a"mistake" and needs to be avoided, to the point, in the past, overtiring is but just a myth. That does not mean someday we might reach that point, like when an axles tires start to touch in the middle.
I forbid my content here from being learned and used by artificial intelligence systems.
[Re: jcc]
#2726357
12/23/19 10:14 AM
12/23/19 10:14 AM
Posts: 7,548 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
I agree as one "over tires" ANY vehicle, other mods need to be taken to utilize the larger(?) tires full traction circle. That DOS NOT mean there is no benefit from over tiring a vehicle without mods. I have not I believe, anywhere suggested there is no downside in over tiring a car, in the realm of additional rotational mass, higher aero drag, aqua planing, cost, unbalancing due to poor size selection per axle, etc. However one can on their own decide if the benefits in "overtiring" is worth the cost, in areas of higher driving performance, decreased braking distance ,etc. My life experience in over 4 decades of "over tiring", and thru nearly all the sharing of others in that time, other then this thread, I have yet to review a solid case of how over tiring is a"mistake" and needs to be avoided, to the point, in the past, overtiring is but just a myth. That does not mean someday we might reach that point, like when an axles tires start to touch in the middle. Hope you are warm and cozy down there, JC. It's 6F up here. "I have yet to review a solid case of how over tiring is a "mistake" and needs to be avoided.." I think ThermoQ is saying don't overtire a car without understanding the car's components are more likely to fail, which may be a mistake that will ruin your day. I think you are saying don't be afraid to "over-tire" your car because better tires have clear and obvious performance benefits right out of the gate. Would that be fair to say? Neither position is wrong - I think it's a choice. Preaching to the choir here, but just to rehash or explain the thinking for my response; Grippier tires allow a car to go faster but has a domino-effect. The most common result is it breaks the car somewhere. And if it breaks, some would be right to call that a mistake because it can end a day of racing, while others label it an opportunity to go faster and find where to make the car stronger.. Some owners want to invest up front and get the benefit while avoiding their car breaking a component, vs owners who are willing to get the benefit and willing to learn if their car breaks and needs repairing later. Most owners probably fall in the middle of these.. When the welds on the RoadRunner's front K-frame crack from the stress induced by the grippy tires ...which I found it on my brother's RR after 1/2 day of tracking on his new tires.. I showed him, and he decided to slow down, but not to stop racing the RR for the day. His drum brakes were already limiting him, so my brother didn't define this failure as a "mistake", but rather a problem he'll deal with later. I took it a step further and listed several additional places he should have stiffeners welded in, front and rear. Each car, each setup, each component, and each attitude towards it, is a choice. We all compromise between benefit vs detriment, speed vs durability, - the increase in performance, weight, durability, cost, etc. and the all significant forces working on the car come via the tires -> cornering, braking and accelerating. Cheers, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: 67SATisfaction]
#2726380
12/23/19 12:15 PM
12/23/19 12:15 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
The road racers on the vette forum run faster times at road atlanta on 275's square vs 315's square. Same compound.
Contact patch for a given weight is always the same square inches.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: Uhcoog1]
#2726421
12/23/19 03:53 PM
12/23/19 03:53 PM
Posts: 23,816 Here
jcc
No soup for you!!!
No soup for you!!!
Here
Contact patch for a given weight is always the same square inches. Maybe, but three things i take away from that: 1. The vettes then need more horsepower 2. I bet a sixpack their 100-0 ft distance is less with the larger tires. 3. Tire pressure can effect contact patch, and the on track, tires aren't statically loaded , so it might be hard here on a keyboard to determine which set of tires are ideally pressured. And "67"satisfaction Has a IMO valid restating of my position on the subject.
[Re: Uhcoog1]
#2726497
12/23/19 10:20 PM
12/23/19 10:20 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Contact patch for a given weight is always the same square inches. Doesn't surprise me, bigger tire requires more heat before the compound gets to it's optimal temperature. It is very important to match that for the given situation, autox, endurance, drag, etc. That said, a softer compound on the 315 setup will likely be faster and not overheat.
[Re: 3eighty3]
#2727758
12/28/19 03:07 PM
12/28/19 03:07 PM
ProSport
Akron, Ohio
3eighty3 that is awesome, do you have any video?
[Re: ProSport]
#2727812
12/28/19 06:40 PM
12/28/19 06:40 PM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
Here's my 63 valiant lemons racecar..
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
[Re: blown340]
#2728024
12/29/19 02:32 PM
12/29/19 02:32 PM
Posts: 752 AZ - The "dry heat" state
71autoxr
Here's my 63 valiant lemons racecar.. Met you guys at Lemons December 2018 at Sears Point we "had" the duster there. Great car.
68 AMX mopars red headed stepchild 69 Dart GT Convertible 340 4 speed 71 Challenger - looks like the avatar!
Re: Picture Thread - Track Racing Mopars!
[Re: 72440CUDA]
#2750923
03/11/20 08:02 AM
03/11/20 08:02 AM
Posts: 23,816 Here
jcc
No soup for you!!!
No soup for you!!!
Here
A 440? Looks good to me
[Re: 72440CUDA]
#2751012
03/11/20 01:12 PM
03/11/20 01:12 PM
Posts: 1,443 NW Chicago suburban area
Mopar Mitch
Nice looking 72 Cuda! and having fun with the car!
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: jcc]
#2751104
03/11/20 08:08 PM
03/11/20 08:08 PM
Posts: 898 Georgia
72440CUDA
Georgia
jcc A 440?
Looks good to me up Yes Sir! Thanks, it’s a work in progress.
