Swapping Knuckles Side to Side #2717564
11/19/19 03:10 PM
11/19/19 03:10 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
When using a factory E Body front-mounted caliper disc brake setup (knuckles, rotors, and calipers) to convert a '69 and earlier B Body to disc brakes with a rear-mounted caliper setup, can you just swap the knuckles side to side to get the calipers in the correct orientation? Thanks!
Re: Swapping Knuckles Side to Side [Re: 67Satty] #2717617
11/19/19 05:46 PM
11/19/19 05:46 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Spindles can be swapped side to side. You have to swap the lower ball joints so the tie rod end is facing the correct way. You will probably also have to come up with a different brake hose.
Re: Swapping Knuckles Side to Side [Re: 67Satty] #2717916
11/20/19 07:56 PM
11/20/19 07:56 PM
AndyF Offline
AndyF  Offline
Knuckles swap but calipers don't. You'll need calipers that are designed to be rear hung. Doctor Diff can get you what you need. He has the correct calipers and hoses.
Re: Swapping Knuckles Side to Side [Re: 67Satty] #2718039
11/21/19 10:53 AM
11/21/19 10:53 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Care to share what your thinking on the need for swapping?
Re: Swapping Knuckles Side to Side [Re: burdar] #2718596
11/23/19 11:59 AM
11/23/19 11:59 AM
moparx Online content
moparx  Online Content
why would you be swapping ball joints side to side ?
beer
Re: Swapping Knuckles Side to Side [Re: jcc] #2719099
11/25/19 10:16 AM
11/25/19 10:16 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Quote
Quote
What I meant is that you can't just undo the upper and lower ball joints and move the entire assembly over to the other side. You have to separate the LBJ from the spindles so the LBJ stays on the correct side.
Re: Swapping Knuckles Side to Side [Re: burdar] #2719118
11/25/19 11:23 AM
11/25/19 11:23 AM
i get it now.
i misunderstood. sorry.
beer
Re: Swapping Knuckles Side to Side [Re: burdar] #2723593
12/12/19 10:42 PM
12/12/19 10:42 PM
n.c.
geo. Offline
geo.  Offline
n.c.
Did this on my brothers Charger 'cause the sway bar on -'69 cars hits the front mounted calipers.
Used '72 knuckles, rotors, and calipers.. Had to get a much longer hose and tie wrap it to keep it from rubbing.
Make sure nothing rubs thru range of steering and suspension travel.
Re: Swapping Knuckles Side to Side [Re: geo.] #2723602
12/12/19 11:51 PM
12/12/19 11:51 PM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
I thought I read somewhere that a '69 Camaro used a 15" brake hose with front discs.
Re: Swapping Knuckles Side to Side [Re: Jjs72D] #2723703
12/13/19 12:11 PM
12/13/19 12:11 PM
i believe that to be correct.
possibly the one DrDiff uses in his kit ?
beer
Re: Swapping Knuckles Side to Side [Re: geo.] #2723905
12/14/19 02:01 AM
12/14/19 02:01 AM
AndyF Offline
AndyF  Offline
Yes that happens if you use the wrong caliper. When you rear mount the calipers you should use a caliper that is designed to be rear mounted. The correct caliper will have the bleeder at the top and the hose coming out the bottom. Then you use a fairly short hose that loops down and back up to the hard line on the frame.
Re: Swapping Knuckles Side to Side [Re: AndyF] #2723984
12/14/19 01:16 PM
12/14/19 01:16 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I had slider calipers produced with 2 bleeder valves so they can be mounted toward the front or toward the rear and still yield ideal hose routing. See below:
https://www.doctordiff.com/73-89-slider-calipers.html
Re: Swapping Knuckles Side to Side [Re: DoctorDiff] #2724095
12/14/19 11:23 PM
12/14/19 11:23 PM
AndyF Offline
AndyF  Offline
That is a good idea. I knew you carried calipers but I didn't realize that you had added the second bleeder screw. Great idea to make the calipers more universal.
Re: Swapping Knuckles Side to Side [Re: AndyF] #2724202
12/15/19 02:42 PM
12/15/19 02:42 PM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
I'll bet that the same thing could be done by someone. Drill and tap the caliper then slip in a standard size bleeder screw. Great idea.
