Rear end swap....Need advice/opinion #2716632
11/17/19 10:17 AM
11/17/19 10:17 AM
None
71rm23 Offline OP
71rm23  Offline OP
None
Gang:
My car's 8 3/4's rear end was rebuilt and I have 0 miles yet. The third member and the housing is leaking (just a few drops on both) so, I dropped it out. Anyway, I have another rear housing, painted it, and need to swap everything from one to the other when I get home from my deployment. Also, I have the manual as well to follow. It should be an easy swap, right? I'll be getting new gaskets and adjuster as well. Am I thinking this right that it should be somewhat easy? Advice/opinions? No, I've never done something like this before but it's a learning tool. Thanks
Re: Rear end swap....Need advice/opinion [Re: 71rm23] #2716656
11/17/19 11:35 AM
11/17/19 11:35 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
What is it about the leak that makes you think that the housing itself is the problem and not a gasket or seal?
Master, again and still
Re: Rear end swap....Need advice/opinion [Re: DaveRS23] #2716687
11/17/19 12:35 PM
11/17/19 12:35 PM
None
71rm23 Offline OP
71rm23  Offline OP
None
Because the original housing was bent, cut to straighten, welded back. It has 1 or 2 minor leaks. Overall, the leaks isn't bad but my OCD wants to NOT have a differential leaking.
Re: Rear end swap....Need advice/opinion [Re: 71rm23] #2716740
11/17/19 02:19 PM
11/17/19 02:19 PM
Guitar Jones Offline
Once again OCD rears it's ugly head, I feel your pain but it should be a straight forward swap.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Rear end swap....Need advice/opinion [Re: 71rm23] #2716760
11/17/19 03:07 PM
11/17/19 03:07 PM
Cab_Burge Online work
Cab_Burge  Online Work
Make sure there are no residual gaskets pieces or sealer left on both sealing surfaces, on the rear end housing and the mating flange surface on the third member scope wrench
Good luck, to bad about the leaky one.
Let us know what you think was causing it to leak after you get it apart thumbs
BTW, I have had used 8 3/4 seep out of the threads on the lower studs due to the soft copper washers being removed and not reused scope whiney A good silicone sealer on those threads are your friend up
Re: Rear end swap....Need advice/opinion [Re: Cab_Burge] #2716767
11/17/19 03:19 PM
11/17/19 03:19 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
X 2 on what the smilie Xpert says ....
THEN spend an hour prepping the HOUSING to glue the gasket to it THEN make the pig flange spotless and oil it up.
Makes a gear change TONZ easier up up up
jsta TRYING to keep up with B C ... penguin
Re: Rear end swap....Need advice/opinion [Re: 71rm23] #2716815
11/17/19 06:21 PM
11/17/19 06:21 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Like posted above it's pretty straightforward but make sure you get the CORRECT seals and gaskets from doctordiff because he will only sell you the correct seals and any other chassis parts you need for the swap.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Rear end swap....Need advice/opinion [Re: fourgearsavoy] #2717045
11/18/19 09:25 AM
11/18/19 09:25 AM
None
71rm23 Offline OP
71rm23  Offline OP
None
Thanks guys. Speaking of Dr. Diff, I see on his site he has all the gaskets as a kit. He also has a more beefier billet adjuster as well. I'll keep everyone posted what I find when I return home to swap them.
Re: Rear end swap....Need advice/opinion [Re: 71rm23] #2717975
11/21/19 01:22 AM
11/21/19 01:22 AM
None
71rm23 Offline OP
71rm23  Offline OP
None
What are your suggestions can I do/use to get surface rust and or to clean out the inside of the axle housing?
Re: Rear end swap....Need advice/opinion [Re: 71rm23] #2717979
11/21/19 01:29 AM
11/21/19 01:29 AM
Are you talking about surface rust on the housing or carrier or on the inside of either one of them?
I use spray Easy Off oven cleaner after rinsing any car part with cleaning solvent that has had oil or grease inside or on the outside of them. If the rust is inside the axle housing your om your own on that, sorry blush
If on the outside can you get it sand blasted? scope up
Re: Rear end swap....Need advice/opinion [Re: Cab_Burge] #2717991
11/21/19 03:07 AM
11/21/19 03:07 AM
None
71rm23 Offline OP
71rm23  Offline OP
None
Surface rust on the inside of the housing
Re: Rear end swap....Need advice/opinion [Re: 71rm23] #2717999
11/21/19 07:11 AM
11/21/19 07:11 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
You can buy a brush with a long wire handle at Harbor freight or other similar store. That’s what I use with naphtha or degreaser.
Re: Rear end swap....Need advice/opinion [Re: fastmark] #2718017
11/21/19 09:15 AM
11/21/19 09:15 AM
None
71rm23 Offline OP
71rm23  Offline OP
None
Also, what is everyone using for the mating surfaces, on either side of the gasket for the third member, if any?
Re: Rear end swap....Need advice/opinion [Re: 71rm23] #2718022
11/21/19 09:52 AM
11/21/19 09:52 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Any chance you have a Redi Strip within driving distance? All of my big pieces like diffs and Ks go to them. Well worth the time and effort to use them and know that ALL of the grease, oil, rust, gaskets, etc is removed from the entire piece. Inside and out.
Re: Rear end swap....Need advice/opinion [Re: DaveRS23] #2718052
11/21/19 11:41 AM
11/21/19 11:41 AM
None
71rm23 Offline OP
71rm23  Offline OP
None
I'll have to see. Good info!
Re: Rear end swap....Need advice/opinion [Re: 71rm23] #2718057
11/21/19 11:59 AM
11/21/19 11:59 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Buy a gallon of EvapoRust. Plug the axle ends and vent. Pour the EvapoRust inside and let it sit. You can rotate the housing every half hour or so(depending on amount of rust) so the liquid will reach every area.
Re: Rear end swap....Need advice/opinion [Re: burdar] #2718266
11/21/19 11:19 PM
11/21/19 11:19 PM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
Citric acid or molasses will do the trick a bit slower than the evaporust
Molasses 1:9 with warm water, let it sit for a day or two, Farm grade has sulphur in it that helps the process
works surprisingly well, generally wont harm NON metallic paints too
