School me on 1970's 15in steel wheel appearance #2716479
11/16/19 05:26 PM
11/16/19 05:26 PM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
So I'm deciding on steel wheels with dog dish wheels for my 72' Charger Rallye. I do not know if the face on 72' model rims has any difference in appearance then any other years. I want to run 15's and probably have the rim widths widened for better tire choices, but mostly want a stock appearance. I don't care if their are part numbers on the rims and not planning to run trim rings. I was thinking Wheel VIntique's might work, but not sure how 'factory' they would appear. Any info, pics and suggestions would be appreciated and thanks in advance.
Re: School me on 1970's 15in steel wheel appearance [Re: migsBIG] #2716528
11/16/19 07:53 PM
11/16/19 07:53 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Re: School me on 1970's 15in steel wheel appearance [Re: Neil] #2716537
11/16/19 08:24 PM
11/16/19 08:24 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Tony's now makes perfect reproductions of the "450" wheels. He can also stamp them with the proper 1972 P/N and dates. This is a correct looking 1972 wheel. The other companies like Wheel Vintiqes just sell steel wheels that accept dog dish caps but also have a different appearance then a factory "070" wheel.
Ron
Re: School me on 1970's 15in steel wheel appearance [Re: Neil] #2716543
11/16/19 09:09 PM
11/16/19 09:09 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Originally Posted by Neil
Thank you for the link. Since there are no specific dates on there, looks like 1970-1973’ish rims look to be very similar or even the same rim with just different part number, if that is the case, then I can probably find cores to work with. I would like to have correct looking, but does not need to be perfect originals for it. Though Tony would make dates and part numbers, I would want larger rims sizes like 15X8 and possibly larger for the rear. This info makes it easier to decide, hopefully I can source something that looks right for the car. Thanks again for the info and link. I miss old (I think his name was Frank or Dick) from Stockton Wheel. Before his tragic end, he was the local guy to have wheels made and customized and was super affordable. His family took over, but not sure how the quality is since his passing. Will have check them out and see how the work. Also, maybe there could be some 14’s rims that could be used as cores if everything look close in appearance.
Re: School me on 1970's 15in steel wheel appearance [Re: migsBIG] #2716753
11/17/19 02:53 PM
11/17/19 02:53 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Migs
The 72 wheel looks NOTHING like a 70-71 450 wheel.
The 72 wheel is 15 x 6.5 and uses a 15" center so the drop to reach the wheel spider (center section) is smaller. There are three nubs to hold on the center cap.
The 70-71 450 wheel is 15 x 7 with a 14" center
If you don't care about the nubs being 3 or 4 because the are going to be covered by a center cap then I would look for B100, D100 and W100. Various years would work.
Then take them to Stockton Wheel. I've used them recently and I have born happy every time. They are getting a little pricey but quality looks good.
M426
Re: School me on 1970's 15in steel wheel appearance [Re: Morty426] #2716790
11/17/19 04:50 PM
11/17/19 04:50 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Migs
M426
That is totally false information, the 72 wheel is just like a 70-71 450 wheel sans the 070 p/n and is also 15x 7. I can't speak after 72 and haven't.
Ron
Re: School me on 1970's 15in steel wheel appearance [Re: RJS] #2717130
11/18/19 12:18 PM
11/18/19 12:18 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Migs
M426
Ron
Thank you both for the info. I am not sure which wheels are correct to be honest so I'm trying to get an idea what will and won't work or what wheels would be good donors for it. If anyone can shed some light on that and what donors are similar, I would greatly appreciate it.
Re: School me on 1970's 15in steel wheel appearance [Re: RJS] #2717161
11/18/19 01:10 PM
11/18/19 01:10 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Migs
M426
Ron
Ron,
You trying to compare Apples and Oranges. You are trying to compare a Steel Wheel (450) to a Rallye wheel (070 for 72). Do they both use a 14" center? Yes they do.
HOWEVER this is a question regarding STEEL rims, not Rallye wheels. The 72 steel wheel does have a 15" center. I have one sitting here along with multiple 450 wheels.
M426
Re: School me on 1970's 15in steel wheel appearance [Re: Morty426] #2717253
11/18/19 05:34 PM
11/18/19 05:34 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
IMHO You are mistaken again, the rallye wheel is "071' the steel wheel is "070" and is same as a "450"
Ron
Re: School me on 1970's 15in steel wheel appearance [Re: RJS] #2717309
11/18/19 09:12 PM
11/18/19 09:12 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I have no dog in this debate but I think the wheel part numbers being thrown around here are causing the confusion.
The 70-71 steelie 15 x 7 is 2944450,
The 1972 steelie 15 x 7 is 3580070.
The 70-71 rallye 15 x 7 is 2944390.
The other later 15 x 7 rallye 3580071, called the Canadian version or over the counter rim has a different size half moon opening.
The 15 x 6.5 rallye for 1972 is part number 3466961.
Both the 450 and 070 steelie 15 x 7 wheels have 4 nub centers
Re: School me on 1970's 15in steel wheel appearance [Re: RJS] #2717361
11/19/19 12:07 AM
11/19/19 12:07 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Ron
Ok thanks Ron. Obviously I was to lazy to go look at my two 071 wheels.
Thanks for setting me right.
Re: School me on 1970's 15in steel wheel appearance [Re: Morty426] #2717458
11/19/19 11:05 AM
11/19/19 11:05 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Ron
Morty I'm not sure by your reply if you are agreeing with me or being sarcastic because again you mention the "071" which is a rallye wheel and not what the OP has asked for. Mccannix has all the info. needed in his post above.
I'm not here to fight with you I was just trying to provide information to the OP. No more no less.
Ron
Re: School me on 1970's 15in steel wheel appearance [Re: RJS] #2717486
11/19/19 12:34 PM
11/19/19 12:34 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I agree.
Other than the part number, the rare 1972 (drop center, 15 x 7 plain Jane steel, 4 nub) "070" wheel appears identical to the earlier 450 wheel.
In addition, the 070 wheel is even less common than the 450 wheel.
Re: School me on 1970's 15in steel wheel appearance [Re: DoctorDiff] #2717536
11/19/19 01:49 PM
11/19/19 01:49 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Wow, did not expect this much attention on the wheels. So the 15X7 wheel 1970-72 wheel are nearly the same except for part numbers. So it that, is the case, then I can't use the centers out of a 14in wheel to get the desired wheel look I wanted? So here is another question. Is there another 15in steel wheel I can steal the center from that are similar to the 450/070 wheel? Would truck/car/van 1970-72 model wheels have the look or rim part numbers I could try to source. Once again, thank you everyone for putting the effort in to helping a member out.
Re: School me on 1970's 15in steel wheel appearance [Re: migsBIG] #2717620
11/19/19 05:53 PM
11/19/19 05:53 PM
Delta BC, Canada
Baller Offline
Baller  Offline
Delta BC, Canada
It's not the center that makes a 450 rim. It's the wide shoulder. Google an image; you'll see the difference. At one time Dr.Diff was using the outer hoops from a Buick(?) and welding in mopar centers as those rims had the wide shoulder (or whatever you want to call it). I almost think that you'd be better off buying the repo's and widening them. That's my plan.
1970 GTX, work in progress...
Re: School me on 1970's 15in steel wheel appearance [Re: Baller] #2717622
11/19/19 06:01 PM
11/19/19 06:01 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Migs as you stated earlier your not looking for exact so just buy wheels from Jegs or Summit or whoever in the Wheel Vintiques brand and get the width and offset you desire.
I was merely letting you and whoever followed aware that Tony's Parts makes perfect "450' copies and can also instead stamp them in the "070" P/N and or dates you need/want when this whole debate went off the rails
I'll attach a picture of what a "450" or "070" wheel looks like.
Ron
Re: School me on 1970's 15in steel wheel appearance [Re: RJS] #2717753
11/20/19 01:52 AM
11/20/19 01:52 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Ron
Ron
Ron
I am not being sarcastic. I was wrong because I had my numbers crossed. If I had gone out and looked at the two 071 wheels I have I would have figured out I was wrong.
I do appreciate that you corrected my error.
My post was a thank you.
Morty
Re: School me on 1970's 15in steel wheel appearance [Re: Morty426] #2717790
11/20/19 10:11 AM
11/20/19 10:11 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
If close is ok.
I hit the U Pulit.and grabbed some 15x7 off some Dippys and like cars. Not cop car ones.
Here in the south they had no rust just old paint and light surface rust. But I blasted them anyway for a good start. Cost was 10 bucks each.
I grabbed 10. And then found 2 Ram Chrager ones to get 2 15x8 so I have 3 sets
They make new 15x8 new and would recommend them for 275/60/15 or so. So the tire sits flat.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: School me on 1970's 15in steel wheel appearance [Re: Morty426] #2717836
11/20/19 01:03 PM
11/20/19 01:03 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Ron
Ron
Ron
Morty
Very Cool Morty!! Typed words are hard to read into sometimes. I never wanted to ruffle feathers just answer posts that I believe I have the knowledge for.
Ron
Re: School me on 1970's 15in steel wheel appearance [Re: RJS] #2717880
11/20/19 04:52 PM
11/20/19 04:52 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Chrysler had other 15x7 steel wheels on their cars. I believe the Magnums in around 1978 had those Black 15x7s with the extra holes that are covered up once the Dog Dish Hub Caps go on it. It is a cheaper wheel to use if you do not need that part number near the valve stem. I was going to use them on my Cuda and use 15x8s on the back that are off I believe a Ram Charger.
1971 HEMI E BODY REGISTRY
