Cam recommenations updated 4/18
#2715686
11/14/19 12:43 PM
11/14/19 12:43 PM
Posts: 935 Deland, Florida
biff426
Deland, Florida
So my son has a 2011 charger 5.7 ex police car. I want to replace the lifters as I know they are most likely getting ready to fail I figure at that point may as well slide a cam in it. This car was well taken care of I know the cop that drove it from a small beach town near me it was well maintained has 90K miles on it. What is a decent cam that is still somewhat manageable to tune? I plan to delete the MDS and I know I will have to limit the VVT. The car has the 308 gear option as well. I would like to get this thing in the 12s it has run low 13s already.
Re: Cam recommenations
[Re: biff426]
#2716583
11/16/19 11:26 PM
11/16/19 11:26 PM
Posts: 554 Mesa , Az
Jambbii
Mesa , Az
I did the cam swap in my wife's durango r/t per Dave's recommendation. I had the heads off and for 270 bucks for cam and springs I figured why not. It is a pretty good boost. In my opinion it needs a tune to take full advantage of it. Have about 6k miles on the swap. No issues so far!
70 Challenger 1960 Town Wagon P Pump 24v cummins project 06 Mega 3500 Drw 2wd 12 Durango R/T 18 Power Wagon 67 A100
[Re: Jambbii]
#2716998
11/18/19 01:38 AM
11/18/19 01:38 AM
Posts: 43,119 Bend,OR USA
Cab_Burge
Are you guys degreeing these new cams or just aligning the dots? HRD, how much lift and duration are they different?
[Re: Cab_Burge]
#2717218
11/18/19 03:32 PM
11/18/19 03:32 PM
Posts: 1,548 Michigan
Kiddart
Cab, I just lined up the dots per what a friend of mine told me to do. It runs really good. I have heard some have degreed them in and they did not run as good? If its good from the factory I figured it was good enough for me
Thank you Kiddart
[Re: Kiddart]
#2717378
11/19/19 01:31 AM
11/19/19 01:31 AM
Posts: 6,560 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Cab, I just lined up the dots per what a friend of mine told me to do. It runs really good. I have heard some have degreed them in and they did not run as good? If its good from the factory I figured it was good enough for me That's assuming replacement parts are the same as the parts they build them out of and in my experience, that's not always a safe assumption. Kevin
[Re: HotRodDave]
#2717547
11/19/19 02:30 PM
11/19/19 02:30 PM
Twostick
Still wishing...
Still wishing...
The computer degrees it in real time. I am curious how people are "degreeing" these cams unless they lock down the phaser (dumb idea). I didn't realize it was a VVT engine. So how do you verify that the camshaft and the ECM agree where the ICL etc is? Kevin
[Re: HotRodDave]
#2726924
12/25/19 09:49 PM
12/25/19 09:49 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
HotRodDave, that spring info you gave is wrong. The 6.4 installed height is taller than the 5.7. A 6.4 spring CB is around 1.4. When installed at a 1.98 in an Eagle head you would be right on CB with a 6.4 cam.
Another thing, the 5.7s springs CB measurements are all over the place. From 1.30 to 1.37. However, the stock mopar springs have really stout pressures.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#2728408
12/30/19 09:02 PM
12/30/19 09:02 PM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
Another thing, the 5.7s springs CB measurements are all over the place. From 1.30 to 1.37. However, the stock mopar springs have really stout pressures. Stock as deviled OEM heads , installed heights ....... Apache Intake 2.055 Exhaust 2.020 Eagle Intake 1.990 Exhaust 2.000..................When we did my 09 ram we removed the factory 0.081 spacer on a Eagle 5.7 and used a .030 shim to make give me some breathing room Part # P5160074 is the Mopar performance spring for the Eagle heads that has a max lift of .625 designed to work with stock 5.7 keepers and locks, they are $280ish from Summit and 240ish from https://www.moparpartsgiant.com/parts/mopar-accessories_spring_valve-p5160074.html
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
[Re: Ray408G3Hemi]
#2728631
12/31/19 06:15 PM
12/31/19 06:15 PM
sixpackgut
Charleston
I just went out to measure an eagle head. No shim I got 2.015. It came with .040 shim. I have a few .080 shims on the peg board so they must have made a change somewhere. Anyway 2.015-.570=1.445. So I really don't see how you can run a 6.4 spring safely at all
Also CB on the one spring out of this eagle head i just checked was 1.39
[Re: HotRodDave]
#2728806
01/01/20 03:12 AM
01/01/20 03:12 AM
sixpackgut
Charleston
I have 6.4 springs on my eagle heads with an SRT8 cam and it runs great, no coil bind and this is not the first one by any means. I could see daylight between every coil with the lifter bled down then shimmed solid with feeler gauges. Theoretical and actual are frequently different. I have 2 .040 shims in there, 3 and I could barely see light through a couple of the coils. Your saying you have .080 shim with springs that came out of 6.4 heads? And cam lift is .571 correct?
