Removing snapped exhaust manifold bolts #2707863
10/17/19 09:43 PM
10/17/19 09:43 PM
NW PA
V10nacuda Offline OP
NW PA
So I finally got my butt in gear and finished yanking the 5.7 out of the donor truck for my Ramcharger swap. I was just going to drop the motor and 545rfe as one, figure how much floor pan work i need to do. (I havent found anyone with the 545rfe swap) Get it running then yank it out and clean it up. Well shiny object syndrome got me and I decided to yank the valve covers to get them blasted while I did everything else.After a few of the valve cover bolts snapped off I decided to pull the exhaust manifolds too and broke 2 on top of the other 2 that were snapped off nearly flush.
So anyone have a full proof procedure for getting them out?
I have dealt witb cast iron heads and snapped bolts....Any alum heads I have had were new and were doused in never seize and never had issues.
Thanks in advance V10
Re: Removing snapped exhaust manifold bolts [Re: V10nacuda] #2707979
10/18/19 10:29 AM
10/18/19 10:29 AM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
If you have a welder, you can weld a nut to the broken stud (even if it broken flush with the head) and then back it out. I've done it and it worked great.
Re: Removing snapped exhaust manifold bolts [Re: blowndart] #2708160
10/18/19 05:23 PM
10/18/19 05:23 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
We dealt with Broken bolts and studs in the mill and learned that if we took a smaller flat washer and plug welded it to the broken stud it was then easier to weld a nut to the flatwasher and get a better cleaner weld.
1970 Duster
Edelbrock headed 408
6.143@110.85 mph
9.73@135.05 mph shifting at 6700 RPM
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Removing snapped exhaust manifold bolts [Re: pittsburghracer] #2708494
10/20/19 11:04 AM
10/20/19 11:04 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Wow, never thought of this, great tip!
Re: Removing snapped exhaust manifold bolts [Re: moparjim79] #2708720
10/20/19 11:44 PM
10/20/19 11:44 PM
NW PA
NW PA
Well got the all out by welding the nut to it! The washer idea is filed in my memory bank for future issues!
Thanks!
V10
Re: Removing snapped exhaust manifold bolts [Re: V10nacuda] #2716174
11/15/19 06:30 PM
11/15/19 06:30 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
Do the manifold gaskets have to be replaced or are they reusable?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Removing snapped exhaust manifold bolts [Re: dfsmopars] #2717140
11/18/19 12:34 PM
11/18/19 12:34 PM
NW PA
NW PA
I believe exhaust gaskets are not reusable.
Re: Removing snapped exhaust manifold bolts [Re: V10nacuda] #2717199
11/18/19 02:49 PM
11/18/19 02:49 PM
Fort Worth, Texas
3hundred Online work
3hundred  Online Work
Fort Worth, Texas
Mine has the 545rfe but it's two wheel drive so I don't know how much help that would be to you. I did put an A-500 into an older 2wd Ramcharger, TONS of room. I simply don't know about the 4x4 and transfer case clearance.
Robert
'68 Fury Convertible
'69 300 Convertible
'93 Ramcharger 5.7 Hemi
'93 Ramcharger 318 sold
'01 3500 4x4 Cummins 6 speed sold
'13 300 S sold
'15 Durango 5.7 Hemi
'16 300 S Hemi
