1967 Coronet Hood Prop #2716718
11/17/19 01:41 PM
11/17/19 01:41 PM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
So I went to a fiberglass hood and need something to keep the hood up. I am using the factory hinges. I tried some misc small springs but the car has a rough idle and the will stay up but will eventually fall. I could probably figure out using the strength of a couple springs together to make it work, but was thinking about a hood prop. Can I get some ideas and maybe some pics of what people have done. Thanks.
RS23L7 4-Speed
Re: 1967 Coronet Hood Prop [Re: Mopar_Mike] #2716744
11/17/19 02:32 PM
11/17/19 02:32 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
who's brand of hood do you have , I bought a VFN hood and got the springs from them, and hood works just like the steel one did with the original springs. check with the hood manufacture.
Re: 1967 Coronet Hood Prop [Re: old_racer] #2716804
11/17/19 05:53 PM
11/17/19 05:53 PM
Danville, NH
Danville, NH
Good idea, I got it used. I think there is a manufactures tag under it I'll have to check. Still interested in hood prop options too if anyone has any. Thanks.
RS23L7 4-Speed
Re: 1967 Coronet Hood Prop [Re: Mopar_Mike] #2716808
11/17/19 06:09 PM
11/17/19 06:09 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I always used a broom stick. boogie
Re: 1967 Coronet Hood Prop [Re: bobby66] #2716817
11/17/19 06:22 PM
11/17/19 06:22 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
I keep one of these in the tool box, works very well smile
HOOD PROP LINK
beer
Re: 1967 Coronet Hood Prop [Re: TJP] #2716818
11/17/19 06:27 PM
11/17/19 06:27 PM
Danville, NH
Danville, NH
Yeah, I did the broom stick thing, just getting tired of doing it that way. Apparently the hood is from U.S Body Source out of FL.
RS23L7 4-Speed
Re: 1967 Coronet Hood Prop [Re: Mopar_Mike] #2716913
11/17/19 09:31 PM
11/17/19 09:31 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Had a deal like that on a Duster, and used a prop rod from a Toyota pickup.
I made a cradle for the thing in its down position, and plugged the hing end into an existing hole in the rad-support/apron gusset.
Nice to not have a separate thing to deal with or misplace.
