How to wetsand shallow crater? #2716686
11/17/19 12:35 PM
11/17/19 12:35 PM
USA
K
ksat Offline OP
ksat  Offline OP
K
USA
I have a small shallow crater that I want to try to wetsand out. It's a solid color single stage paint. Should I use a hard block or a soft pad to do that?
Re: How to wetsand shallow crater? [Re: ksat] #2716698
11/17/19 01:03 PM
11/17/19 01:03 PM
USA
hudsonhornet7x Offline
USA
I would use a hard block, like a Dura-Block, and only wet sand what you think is necessary. It can be a slippery slope to not burn through.
Re: How to wetsand shallow crater? [Re: hudsonhornet7x] #2716781
11/17/19 04:14 PM
11/17/19 04:14 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Obviously I can't see the crater, but unless you have enough paint and the crater is quite shallow, you're at risk of cutting through the paint as you level it to the depth of the crater.
Your option is to touch that crater up with a dab of paint, let it sit for a few days, then level the touch-up down to the other paint.
Or, a dab of clear in the crater if you don't have leftover paint.
Re: How to wetsand shallow crater? [Re: topside] #2716863
11/17/19 07:57 PM
11/17/19 07:57 PM
USA
K
ksat Offline OP
ksat  Offline OP
K
USA
I still have paint. What grit should I scuff it with before applying a dab of paint?
Re: How to wetsand shallow crater? [Re: ksat] #2716915
11/17/19 09:36 PM
11/17/19 09:36 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
No rougher than 600, since whatever scratches you put in have to be removed later.
If it adheres without scuffing, even better.
Re: How to wetsand shallow crater? [Re: topside] #2716960
11/17/19 10:31 PM
11/17/19 10:31 PM
USA
K
ksat Offline OP
ksat  Offline OP
K
USA
I'll give that a try then. Thanks
