Re: School me on 1970's 15in steel wheel appearance
[Re: migsBIG]
#2716528
11/16/19 07:53 PM
11/16/19 07:53 PM
Posts: 20,354 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
[Re: Neil]
#2716543
11/16/19 09:09 PM
11/16/19 09:09 PM
Posts: 21,599 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
Thank you for the link. Since there are no specific dates on there, looks like 1970-1973’ish rims look to be very similar or even the same rim with just different part number, if that is the case, then I can probably find cores to work with. I would like to have correct looking, but does not need to be perfect originals for it. Though Tony would make dates and part numbers, I would want larger rims sizes like 15X8 and possibly larger for the rear. This info makes it easier to decide, hopefully I can source something that looks right for the car. Thanks again for the info and link. I miss old (I think his name was Frank or Dick) from Stockton Wheel. Before his tragic end, he was the local guy to have wheels made and customized and was super affordable. His family took over, but not sure how the quality is since his passing. Will have check them out and see how the work. Also, maybe there could be some 14’s rims that could be used as cores if everything look close in appearance.
[Re: migsBIG]
#2716753
11/17/19 02:53 PM
11/17/19 02:53 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Thank you for the link. Since there are no specific dates on there, looks like 1970-1973’ish rims look to be very similar or even the same rim with just different part number, if that is the case, then I can probably find cores to work with. I would like to have correct looking, but does not need to be perfect originals for it. Though Tony would make dates and part numbers, I would want larger rims sizes like 15X8 and possibly larger for the rear. This info makes it easier to decide, hopefully I can source something that looks right for the car. Thanks again for the info and link. I miss old (I think his name was Frank or Dick) from Stockton Wheel. Before his tragic end, he was the local guy to have wheels made and customized and was super affordable. His family took over, but not sure how the quality is since his passing. Will have check them out and see how the work. Also, maybe there could be some 14’s rims that could be used as cores if everything look close in appearance. Migs The 72 wheel looks NOTHING like a 70-71 450 wheel. The 72 wheel is 15 x 6.5 and uses a 15" center so the drop to reach the wheel spider (center section) is smaller. There are three nubs to hold on the center cap. The 70-71 450 wheel is 15 x 7 with a 14" center If you don't care about the nubs being 3 or 4 because the are going to be covered by a center cap then I would look for B100, D100 and W100. Various years would work. Then take them to Stockton Wheel. I've used them recently and I have born happy every time. They are getting a little pricey but quality looks good. M426
[Re: Morty426]
#2716790
11/17/19 04:50 PM
11/17/19 04:50 PM
Posts: 6,221 JERSEY
RJS
JERSEY
Thank you for the link. Since there are no specific dates on there, looks like 1970-1973’ish rims look to be very similar or even the same rim with just different part number, if that is the case, then I can probably find cores to work with. I would like to have correct looking, but does not need to be perfect originals for it. Though Tony would make dates and part numbers, I would want larger rims sizes like 15X8 and possibly larger for the rear. This info makes it easier to decide, hopefully I can source something that looks right for the car. Thanks again for the info and link. I miss old (I think his name was Frank or Dick) from Stockton Wheel. Before his tragic end, he was the local guy to have wheels made and customized and was super affordable. His family took over, but not sure how the quality is since his passing. Will have check them out and see how the work. Also, maybe there could be some 14’s rims that could be used as cores if everything look close in appearance. Migs The 72 wheel looks NOTHING like a 70-71 450 wheel. The 72 wheel is 15 x 6.5 and uses a 15" center so the drop to reach the wheel spider (center section) is smaller. There are three nubs to hold on the center cap. The 70-71 450 wheel is 15 x 7 with a 14" center If you don't care about the nubs being 3 or 4 because the are going to be covered by a center cap then I would look for B100, D100 and W100. Various years would work. Then take them to Stockton Wheel. I've used them recently and I have born happy every time. They are getting a little pricey but quality looks good. M426 That is totally false information, the 72 wheel is just like a 70-71 450 wheel sans the 070 p/n and is also 15x 7. I can't speak after 72 and haven't. Ron
[Re: RJS]
#2717130
11/18/19 12:18 PM
11/18/19 12:18 PM
migsBIG
San Jose,CA
Thank you for the link. Since there are no specific dates on there, looks like 1970-1973’ish rims look to be very similar or even the same rim with just different part number, if that is the case, then I can probably find cores to work with. I would like to have correct looking, but does not need to be perfect originals for it. Though Tony would make dates and part numbers, I would want larger rims sizes like 15X8 and possibly larger for the rear. This info makes it easier to decide, hopefully I can source something that looks right for the car. Thanks again for the info and link. I miss old (I think his name was Frank or Dick) from Stockton Wheel. Before his tragic end, he was the local guy to have wheels made and customized and was super affordable. His family took over, but not sure how the quality is since his passing. Will have check them out and see how the work. Also, maybe there could be some 14’s rims that could be used as cores if everything look close in appearance. Migs The 72 wheel looks NOTHING like a 70-71 450 wheel. The 72 wheel is 15 x 6.5 and uses a 15" center so the drop to reach the wheel spider (center section) is smaller. There are three nubs to hold on the center cap. The 70-71 450 wheel is 15 x 7 with a 14" center If you don't care about the nubs being 3 or 4 because the are going to be covered by a center cap then I would look for B100, D100 and W100. Various years would work. Then take them to Stockton Wheel. I've used them recently and I have born happy every time. They are getting a little pricey but quality looks good. M426 That is totally false information, the 72 wheel is just like a 70-71 450 wheel sans the 070 p/n and is also 15x 7. I can't speak after 72 and haven't. Ron Thank you both for the info. I am not sure which wheels are correct to be honest so I'm trying to get an idea what will and won't work or what wheels would be good donors for it. If anyone can shed some light on that and what donors are similar, I would greatly appreciate it.
[Re: RJS]
#2717161
11/18/19 01:10 PM
11/18/19 01:10 PM
Morty426
Sacramento CA
Thank you for the link. Since there are no specific dates on there, looks like 1970-1973’ish rims look to be very similar or even the same rim with just different part number, if that is the case, then I can probably find cores to work with. I would like to have correct looking, but does not need to be perfect originals for it. Though Tony would make dates and part numbers, I would want larger rims sizes like 15X8 and possibly larger for the rear. This info makes it easier to decide, hopefully I can source something that looks right for the car. Thanks again for the info and link. I miss old (I think his name was Frank or Dick) from Stockton Wheel. Before his tragic end, he was the local guy to have wheels made and customized and was super affordable. His family took over, but not sure how the quality is since his passing. Will have check them out and see how the work. Also, maybe there could be some 14’s rims that could be used as cores if everything look close in appearance. Migs The 72 wheel looks NOTHING like a 70-71 450 wheel. The 72 wheel is 15 x 6.5 and uses a 15" center so the drop to reach the wheel spider (center section) is smaller. There are three nubs to hold on the center cap. The 70-71 450 wheel is 15 x 7 with a 14" center If you don't care about the nubs being 3 or 4 because the are going to be covered by a center cap then I would look for B100, D100 and W100. Various years would work. Then take them to Stockton Wheel. I've used them recently and I have born happy every time. They are getting a little pricey but quality looks good. M426 That is totally false information, the 72 wheel is just like a 70-71 450 wheel sans the 070 p/n and is also 15x 7. I can't speak after 72 and haven't. Ron Ron, You trying to compare Apples and Oranges. You are trying to compare a Steel Wheel (450) to a Rallye wheel (070 for 72). Do they both use a 14" center? Yes they do. HOWEVER this is a question regarding STEEL rims, not Rallye wheels. The 72 steel wheel does have a 15" center. I have one sitting here along with multiple 450 wheels. Thanks M426
[Re: RJS]
#2717361
11/19/19 12:07 AM
11/19/19 12:07 AM
Morty426
Sacramento CA
IMHO You are mistaken again, the rallye wheel is "071' the steel wheel is "070" and is same as a "450" Ron Ok thanks Ron. Obviously I was to lazy to go look at my two 071 wheels. Thanks for setting me right.
[Re: Morty426]
#2717458
11/19/19 11:05 AM
11/19/19 11:05 AM
Posts: 6,221 JERSEY
RJS
JERSEY
IMHO You are mistaken again, the rallye wheel is "071' the steel wheel is "070" and is same as a "450" Ron Ok thanks Ron. Obviously I was to lazy to go look at my two 071 wheels. Thanks for setting me right. Morty I'm not sure by your reply if you are agreeing with me or being sarcastic because again you mention the "071" which is a rallye wheel and not what the OP has asked for. Mccannix has all the info. needed in his post above. I'm not here to fight with you I was just trying to provide information to the OP. No more no less. Ron
[Re: migsBIG]
#2717620
11/19/19 05:53 PM
11/19/19 05:53 PM
Posts: 382 Delta BC, Canada
Baller
Delta BC, Canada
It's not the center that makes a 450 rim. It's the wide shoulder. Google an image; you'll see the difference. At one time Dr.Diff was using the outer hoops from a Buick(?) and welding in mopar centers as those rims had the wide shoulder (or whatever you want to call it). I almost think that you'd be better off buying the repo's and widening them. That's my plan.
1970 GTX, work in progress...
[Re: RJS]
#2717753
11/20/19 01:52 AM
11/20/19 01:52 AM
Morty426
Sacramento CA
IMHO You are mistaken again, the rallye wheel is "071' the steel wheel is "070" and is same as a "450" Ron Ok thanks Ron. Obviously I was to lazy to go look at my two 071 wheels. Thanks for setting me right. Morty I'm not sure by your reply if you are agreeing with me or being sarcastic because again you mention the "071" which is a rallye wheel and not what the OP has asked for. Mccannix has all the info. needed in his post above. I'm not here to fight with you I was just trying to provide information to the OP. No more no less. Ron Ron I am not being sarcastic. I was wrong because I had my numbers crossed. If I had gone out and looked at the two 071 wheels I have I would have figured out I was wrong. I do appreciate that you corrected my error. My post was a thank you. Thanks Morty
[Re: Morty426]
#2717836
11/20/19 01:03 PM
11/20/19 01:03 PM
Posts: 6,221 JERSEY
RJS
JERSEY
IMHO You are mistaken again, the rallye wheel is "071' the steel wheel is "070" and is same as a "450" Ron Ok thanks Ron. Obviously I was to lazy to go look at my two 071 wheels. Thanks for setting me right. Morty I'm not sure by your reply if you are agreeing with me or being sarcastic because again you mention the "071" which is a rallye wheel and not what the OP has asked for. Mccannix has all the info. needed in his post above. I'm not here to fight with you I was just trying to provide information to the OP. No more no less. Ron Ron I am not being sarcastic. I was wrong because I had my numbers crossed. If I had gone out and looked at the two 071 wheels I have I would have figured out I was wrong. I do appreciate that you corrected my error. My post was a thank you. Thanks Morty Very Cool Morty!! Typed words are hard to read into sometimes. I never wanted to ruffle feathers just answer posts that I believe I have the knowledge for. Ron
[Re: RJS]
#2717880
11/20/19 04:52 PM
11/20/19 04:52 PM
Posts: 5,103 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Chrysler had other 15x7 steel wheels on their cars. I believe the Magnums in around 1978 had those Black 15x7s with the extra holes that are covered up once the Dog Dish Hub Caps go on it. It is a cheaper wheel to use if you do not need that part number near the valve stem. I was going to use them on my Cuda and use 15x8s on the back that are off I believe a Ram Charger.
1971 HEMI E BODY REGISTRY
