How many miles per oil change on your Cummin trucks?
#2716395
11/16/19 01:59 PM
11/16/19 01:59 PM
Posts: 43,115 Bend,OR USA
Cab_Burge
I usually don't post on here but I'm wondering what most of you guys with the 24 valve Cummins motors change your oil and filter at? I currently have a 2006 Ram 3500 single wheel 4x4 4 door as my daily driver, I've tried to change the oil and filter between 3500 to 4000 miles, it has a little over 150,000 miles on it now. I was told by the local dodge truck fleet salesman to change oil at 7500 miles, not at 3500 miles The truck sits a lot now but I do use it to tow a 24 Ft. enclosed race car trailer with my bracket car in it, normal trace rip length is between 45 up to 850 miles depending on where I'm racing at. I do a lot of local short trip driving also, probably around 90 % of its normal use. All comments appreciated
Re: How many miles per oil change on your Cummin trucks?
[Re: Uberpube]
#2716486
11/16/19 05:46 PM
11/16/19 05:46 PM
Posts: 944 Central Michigan
nuthinbutmopar
Central Michigan
Oil analysis is your friend! Get a Wix 24077 kit or 3; they're about $22 each on Amazon, but my local Auto Value has them at $15. Next time you're due, pull a sample and send it in. You'll get valuable information on your oil's condition (fuel/coolant/water contamination, additives, etc.) and a recommendation on whether to change the oil or resample at the next service interval. In my Jeep Liberty CRD, I was changing the filter at the recommended 6,750 miles and the oil every 13,000, and could have gone further. With a kit and the postage being about the same price as 2 quarts of oil, it's worth having the detailed info. Also, the reports come with the data from previous tests, and graphs showing change over time for the critical data points.
[Re: Cab_Burge]
#2716596
11/17/19 12:26 AM
11/17/19 12:26 AM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
'04 DR non-HO, 328,000miles. 3K for 1st 100,000 (service contract), 5K between since I've been doing them. $14.00 Walmart, Mopar filter and Chevron Delo-400 its whole life. I have used a couple different Wix filters from time to time and it currently has a K&N for the first time. It was a gift and I didn't have a Mopar filter. Fuel filter every other oil change. Trans. and diff. every 30,000. I've burnt the paint from the diff cover a couple times. Mopar diff oil is like $18.00 a quart. 4 quarts. The reusable gaskets are really good! I'm now on my second, billet, trans. input shaft after it was upgraded in 2010. Two water pumps, an injector, two APP sensors and a belt tensioner is all I've ever done to keep the engine running.
[Re: Cab_Burge]
#2716630
11/17/19 10:02 AM
11/17/19 10:02 AM
Posts: 6,560 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I usually don't post on here but I'm wondering what most of you guys with the 24 valve Cummins motors change your oil and filter at? I currently have a 2006 Ram 3500 single wheel 4x4 4 door as my daily driver, I've tried to change the oil and filter between 3500 to 4000 miles, it has a little over 150,000 miles on it now. I was told by the local dodge truck fleet salesman to change oil at 7500 miles, not at 3500 miles The truck sits a lot now but I do use it to tow a 24 Ft. enclosed race car trailer with my bracket car in it, normal trace rip length is between 45 up to 850 miles depending on where I'm racing at. I do a lot of local short trip driving also, probably around 90 % of its normal use. All comments appreciated That short trip around town stuff can be hard on the oil because it never gets hot enough for long enough to boil off condensation and other contaminants so your change intervals could be a good thing. An oil analysis at your next change can tell you if it's necessary or if it's ok to run it out to 7500 which is normal. An analysis can also let you extend the drain interval to filter at 7500 and oil and filter at 15,000. Probably false economy given it's only 3 gallons of oil or so and you aren't putting on 150,000 miles a year. Kevin
[Re: JDMopar]
#2716654
11/17/19 11:31 AM
11/17/19 11:31 AM
Posts: 16,133 Mesa, Arizona
dart4forte
Mesa, Arizona
2007 CTD, I run AMS OIL. Bought the truck through Dave Smith. I ran their oil until I hade 15k on the motor then switched to AMS. The interval at first was 12,000 mile however AMS changed it to 7500. This was due to the PCV system on the 07 5.9s running into the valve covers. Caused the oil to become dirtier a lot sooner. I checked the oil religiously using WIX filters. I also do a valve adjustment every 100k. At that time the valve cover is cleaned out removing any soot or sludge that has built up. Getting ready to turn over to 300k
Abe Lincoln
[Re: J_BODY]
#2718049
11/21/19 11:30 AM
11/21/19 11:30 AM
Posts: 16,471 On the run…
BloFish
On the run…
When I bought my’06 the dealership offered free oil changes for life. They call me every 4 months and ask if I want to schedule an appointment for my 3K Mile oil change. I have 115k on it now and still going strong.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: Cab_Burge]
#2718812
11/24/19 10:57 AM
11/24/19 10:57 AM
Posts: 554 Mesa , Az
Jambbii
Mesa , Az
Like mentioned before oil analysis is your friend. I put about 5k a year on my 06 now and it gets changed just once annually . I did have the oil analyzed for a few years and I kept stretching intervals when it was my daily driver and I could easily go past 6k. I think there are tons of variables when it comes to this question so you need to get a baseline and go from there. My truck has 145k on it now and every time I have to tear into the engine (self induced) it looks great. I think most oils are sufficient now nowadays but have ran Rotella t6 in this truck for the past 10 years.
70 Challenger 1960 Town Wagon P Pump 24v cummins project 06 Mega 3500 Drw 2wd 12 Durango R/T 18 Power Wagon 67 A100
[Re: Cab_Burge]
#2718925
11/24/19 04:35 PM
11/24/19 04:35 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
I friend of the family drove a older 12 valve 5.9 in a dulley 3500. Never did short city driving, all long haul. He was running a GSA contract run from Seattle to LA, then to NY, NY and back to Seattle pulling a 5th wheel 6 car ramp trailer. Last I knew he had over 1.2 Million miles on the truck and never has had any engine issues. He was doing the 3,000 Oil Change Interval until warranty run out. He then started doing Blackstone Labs testing. He did add the AMSOIL by-pass fitration system and Blackstone tests had him just changing all oil filters at 15,000 miles and with the filter makeup oil and what oil added as needed he was at about 50,000 miles before Blackstone said to dump it. They said the oil was good for another 15,000 miles but it would then be borderline on the TBN scale. Since he was doing about 100,000 miles a year it was two changes a year, Rotella T6 5W40 winter time and T5 15W40 summer.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Dave_J]
#2726533
12/24/19 09:27 AM
12/24/19 09:27 AM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
I have an ‘02 2500 Cummins 4x4. I change every 10,000 miles I use Valvoline Premium Blue and Fleetguard Stratapore filters. Bought the truck a couple years ago at 130k, I’m at 250k now.
If I can just get the damned thing to STOP going in and out of lockup it’d be a good truck. I might switch to an NV5600 6 speed. Other than that, no performance mods. No chip, no tuner no injectors, stock transmission. I’d really like to turn up the heat on it, what am I missing? More go power would be nice.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: mopardude318]
#2726706
12/24/19 09:51 PM
12/24/19 09:51 PM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
If I can just get the damned thing to STOP going in and out of lockup it’d be a good truck. I might switch to an NV5600 6 speed. Other than that, no performance mods. No chip, no tuner no injectors, stock transmission. I’d really like to turn up the heat on it, what am I missing? More go power would be nice. You need to relocate and sheild that large blk/tan ground wire that runs over the top of your alternator. Made a lot of $$ doing that back in the day.
[Re: J_BODY]
#2728026
12/29/19 03:39 PM
12/29/19 03:39 PM
Posts: 1,881 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
If I can just get the damned thing to STOP going in and out of lockup it’d be a good truck. I might switch to an NV5600 6 speed. Other than that, no performance mods. No chip, no tuner no injectors, stock transmission. I’d really like to turn up the heat on it, what am I missing? More go power would be nice. You need to relocate and sheild that large blk/tan ground wire that runs over the top of your alternator. Made a lot of $$ doing that back in the day. More info on this please:) and thanks
[Re: RTSrunner]
#2729602
01/03/20 10:29 AM
01/03/20 10:29 AM
Posts: 3,920 Richmond, Indiana
19swinger70
Richmond, Indiana
I only put around 2000 miles a year on my '04 1 ton with 24 valve. I change the oil once a year, and sometimes slip to 18 months depending on circumstances. Clearly, this is not my daily driver!
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: 19swinger70]
#2729658
01/03/20 02:17 PM
01/03/20 02:17 PM
Posts: 421 montana
BANDIT
montana
I go 4000-4500 miles on my 05, usually an analysis every other. Only put about 6k per year towing to and from track. No daily driving. Rotella 15-40, stratophore filter. Probly a little early, but it’s cheap insurance. Jim
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
